300zx barely idles and revs are limited
Old Apr 16, 2014 | 10:31 AM
todd5854's Avatar
1985 300zx 2+2 manual n/a t-tops maroon with an analog dash.. 276,000 miles
Went to start the Z today, and it idled a little rough as it always does (ONLY when cold, i guess chts) and it warmed up normally. took it around the block, and noticed a DRASTIC increase in power. It has never been that fast.
Anyway, I went to hit the gas a second or third time, and I was jerked forward.. the car would not exceed 1500-2000 RPMs..if I hit the gas, it would stumble and nearly stall. .if i pushed the clutch in, it would go to 300-500rpm, and then stall. I limped it to a gas station, thinking it was low on fuel. Put 93 octane in as I always do, and started it up. same idle problem, only now my rev limiter was limited to 3500 RPM. AFTER fueling up, it still had the same idle problem, but now if I hit the gas, it would run normally except to 3500rpm. I got the car home safely.
Where to start.... Fuel pump, grounds, or ECU codes?
Old Apr 16, 2014 | 11:24 AM
Originally Posted by todd5854
or ECU codes?
Yes.
Old Apr 16, 2014 | 12:13 PM
todd5854's Avatar
I have to leave for work in a few minutes so I didn't get to read the codes yet. But I played with it more, no change still. i noticed that at other throttle positions, that "governed" rpm is lower. at about half throttle it seems to be governed to 2000. Occasionally it makes a LOUD backfire, suggesting the mixture is off or something. I heard a noise that sounded like drinking from a nearly empty cup from a straw, maybe the fuel pump is bad afterall.
Old Apr 17, 2014 | 08:57 AM
Gerbil's Avatar
Air Flow Meter
My best guess is the Air flow meter (silver box on the intake, next to the fan, drivers side) is intermittently losing connection. Unplug the connector and look for any corrosion on the terminals and clean accordingly.
The engine retards to 2000 rpms when the air flow meter is disconnected or giving off odd readings. Check yo codes to confirm, its really easy to do.
Old Apr 17, 2014 | 08:47 PM
todd5854's Avatar
Update:
When the car is cold, it runs normally. Once it warms up and lowers its idle, that's when I have problems. I am no professional mechanic but to me this points to CHTS, cam position sensor, or AFM. It also tells me I need to run my codes.
Old Apr 17, 2014 | 09:12 PM
rogerz's Avatar
Grumpy & Helpful
codes usually not much help. chts prossible but you need to do this
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
try spraying some maf cleaner in the maf
ur2slow
May 9, 2012 05:03 PM
sdkid123
Mar 7, 2011 04:59 PM
dreyg35
Apr 23, 2008 08:15 PM
snowmanZ
FS: 300ZX (90-96)
Mar 26, 2005 11:03 AM
beez
Dec 23, 2004 08:20 AM
