1987 300zx non-turbo over heats
Old Jul 15, 2011 | 01:00 PM
turtle10433's Avatar
hi im new here and cant figure out why my car overheats quickly and is always empty on coolant after i fill it and let it run or sit for a while. so far i've checked the radiator and checked for cracks.
Old Jul 15, 2011 | 01:09 PM
tonsoffun300zx's Avatar
West Coast!
go to autozone and rent one of there cooling system pressure testers and try that and if the cooling system dosen't hold pressure then you know whats up just make sure you do it dry so you can look for wet spots
Old Jul 15, 2011 | 02:24 PM
Flacster's Avatar
If your always out of coolent it has to he leaking somewhere. I would have to say your water pump is no good.
Old Jul 15, 2011 | 03:16 PM
AZ-ZBum's Avatar
Great. Another idiot who can't use punctuation and grammar. Seems to be an endless supply of them lately. And notice they all seem to have heating/cooling issues?
Stay in school.
Pay attention in English class.
Learn to post intelligent looking posts with punctuation. You'll get more/better help that way.
If you're losing coolant and you can't find the leak, I'd suspect a blown head gasket.
Old Sep 14, 2011 | 12:38 PM
bbleroy's Avatar
Z31 overheating
My overheating problem went away once I replaced the radiator, added a thermostat, engine flush, etc. I am a happy camper even though it cost me $400.
Old Sep 22, 2011 | 01:51 PM
anderlinedr's Avatar
I replaced everything on my 88 related to the cooling except for the head gaskets. Could be leaking out of the thermostat as well. It's very hard to tighten all of the bolts up for the thermostat unless you have a universal joint/knuckle. Maybe (and I don't know much about the history of your car) the tech/person who replaced the thermostat (or it's never been replaced) didn't get it all the way tight.
Old Sep 22, 2011 | 02:03 PM
West Coast!
have you gone to autozone and got the pressure tester yet? and for az-zbum's suggestion does your oil look like chocolate milk(bubbly)? cause if it does then it's the H/G
Old Sep 22, 2011 | 03:31 PM
rogerz's Avatar
Grumpy & Helpful
if you don't see it leaking on the ground then it is going out the tailpipe by way of a blown head gasket. leaking water pump you will see it on the ground (under the car if you haven't figured out gravity yet)
Old Sep 22, 2011 | 04:44 PM
You most likely just need to bleed the cooling system. Probably need to check the fan clutch too.
Genuts
FS: 300ZX (84-89)
Feb 5, 2014 08:08 AM
MMiskoe
FS: 300ZX (84-89)
May 15, 2013 07:20 PM
Mikey21
FS: 300ZX (84-89)
Aug 5, 2010 04:44 PM
turboz31
FS: 300ZX (84-89)
Jul 2, 2006 12:20 AM
teamadidas
FS: 300ZX (84-89)
Oct 3, 2004 03:07 PM
