Noise from caliper?
Old Sep 20, 2004 | 06:13 AM
dkrzan's Avatar
Noise from caliper?
Ok whenever i hit a bump i hear a clank from the back left wheel. sometimes when i take off from a stop i hear a grinding noise. hard to describe the noise. anyone have any clue what this could be? if it makes the noise i can touch the brakes and make it stop. shocks, brakes ,and rotors are new. problem persists after those were replaced. no visible damage under car with wheels off and in the air. any help appreciated. thx
Old Sep 20, 2004 | 05:25 PM
johnZboy's Avatar
Distinquished Guest
E-brake cable is rusted and siezing, or, the caliper is siezing. Inspect and lube the cable first, it's less expensive to service and may fix you problem.
Old Sep 30, 2004 | 02:11 PM
maroon300zx's Avatar
change it
change your brake pads. when it gets worn out there's an metal indicator attached to your pads, that grinds with brake disk when worn out.
steezy300
Jul 1, 2015 07:57 AM
zfanman
Oct 30, 2008 11:36 PM
jamoncabbage
Aug 16, 2007 03:46 PM
wgc_3
Dec 2, 2006 08:36 AM
Carl's Z
Nov 14, 2005 01:32 PM
