No Brakes
Old Feb 17, 2005 | 08:02 PM
fliq's Avatar
no braaakes
if your booster were bad you pedal would usually have a lot of pressure with no stopping power. I would opt toward the master cylinder, break lines, calipers or wheel cylinders. if your fluid level is good in the master cylinder. bleed the breaks. replace the expended fluid and pump the brakes, if the fluid goes down you have a leak somewhere.easy enough to find by pushing your vehicle to dry ground before you pump. if your fluid does not go down at this point and still have no pressure it is more than likely your master cylinder
ddatsun
22
Nov 9, 2007 08:47 AM
Smittyz33
Mar 21, 2006 11:33 AM
Fast240Z
Other Cars
Dec 1, 2005 12:35 PM
S1j9m85
May 15, 2004 10:48 AM
Al Dukes
Oct 11, 2003 01:23 PM
