help with bolt on spacers
Anything with math and wheels and fitment gives me anxiety. I have some basic questions about bolt-on spacers.
I own an '87 turbo. It has the stance coilover set-up and Enkei TS-5's. 9in front wheels. 9.5in width real wheels. I like the look in the front, but I'm wishing I went wider in the back.
I don't trust myself to do the math that is needed to figure out the size of the spacers I need to get the right fitment, so I took my car to a shop. The shop said I could probably do 1.25in bolt on spacers in the back. Assuming 1.25in spacers will fit, I should be looking for bolt-on spacers that fit and use 5x114.3 threading, correct? Any particular brand you guys recommend?
Dumb question: Can I use bolt-on spacers that have the same threading as my '87, which is 5x114.3? A website talked about how using a spacer with the same threading as your vehicle doesn't work, but that doesn't make sense to me.
I got my 1 inch spacers from Amazon, Same thread pattern and spacing as my 85 Z31T. However, with my 245 wide rear tires, It barely fits. I should have gone with the .75 inch spacer. What you need depends on your choice of the wheel width, diameter, back spacing, and offset and tire width and aspect ratio.
KSpakes87
12
Mar 6, 2013 07:46 PM
