Heavy Duty Suspension?
Old Sep 6, 2007 | 02:54 PM
passaphist's Avatar
where can i get suspension for my z31 that will drop it about 1.5" - 2" and withstand the weight and power of a slightly modded chevy sb 350?
Old Sep 6, 2007 | 03:12 PM
oh man... why ya gotta bastardize the Z31 with a sbc?
Old Sep 6, 2007 | 03:19 PM
passaphist's Avatar
more power for the money and alot easier to find parts in my area. not to mention itll look good when i take it to the shows next year.
Old Sep 6, 2007 | 07:31 PM
tekanitrus's Avatar
your best bet is to take off one of the old springs and go to a spring shop and have a set custom made. also you might have carb clearance issues.
if you can find an olds 260 V8 the compact size would make for a much easier size while still enjoying the easy to find parts... they came in the late 70's olds.
Old Sep 21, 2007 | 07:48 AM
PooFlinginMonke's Avatar
Since the 260, 307, 350, and 403 are exactly the same size........
Old Sep 29, 2007 | 06:27 PM
Racinjitter's Avatar
Right here... Clicky
Old Sep 30, 2007 | 03:49 PM
AZ-ZBum's Avatar
An SBC that looks like it was done properly and have a bunch of power will cost a lot more money than a VG30ET that looks good and has the same amount of power. And what parts are you having a problem finding? I've never had an issue with parts.
Old Sep 30, 2007 | 04:05 PM
entropy31's Avatar
The Cake Is A Lie!
agreed. not cost effective to go SBC. Dr. Buddah did the swap, and did it right, but it was definately not the cheap route.
Old Sep 30, 2007 | 04:33 PM
you may be able to get more power for less money with the vg30t, but the vg30t wont run as reliably in the higher HP numbers as an sbc..
Old Oct 2, 2007 | 02:53 PM
AZ-ZBum's Avatar
An engine is as reliable as you want to make it. There are a few 400+ hp VG motors running around reliably.
Old Oct 2, 2007 | 06:12 PM
Reliable = DON'T BE CHEAP.
Old Oct 2, 2007 | 06:25 PM
which makes the VG the HP-$ just a little cheaper then the RB, the only problem with the cost of the RB is the purchasing of the motor itself..
Old Oct 4, 2007 | 05:14 AM
passaphist's Avatar
i already have a 350 with a t-5 transimission. money im not to worried about any more. plus im keeping my vg and building that up on a stand next winter to put into another z later on. for the most part this project is to keep me outta trouble this winter and give me a reason to get away from people.
87pyro3
Apr 13, 2013 09:48 AM
Lesnocker
Apr 6, 2012 08:04 PM
thxone
Jun 6, 2007 12:05 PM
Fast240Z
Apr 22, 2006 06:37 PM
FLiPSyDe71
Oct 5, 2004 07:15 PM
