Diff mount modification?
Old Nov 3, 2006 | 03:24 PM
my86z's Avatar
Well, this may be a silly question. But I just gotta ask.
Has any one tried filling the rear differential mount with polyeurothane to make it stiffer/last longer?
I've done this with other vehicle's motor and transmission mounts with fairly good results. Just wondering if anyone here has tried it.
Old Nov 7, 2006 | 07:23 PM
autoworkz's Avatar
seen people drill through the parts and bolt them together, cheap solid mount
Old Nov 8, 2006 | 05:48 PM
johnZboy's Avatar
Distinquished Guest
Stiffer? Longer lasting? Try that little blue pill....
Or maybe this will work.
Old Nov 8, 2006 | 05:51 PM
my86z's Avatar
Now, that I might be able to pull off. What thickness would be recommended for the material? 1/4", 1/2", 1/8"?
Old Nov 8, 2006 | 06:12 PM
johnZboy's Avatar
Distinquished Guest
I didn't mic it. It was just some scrap from another job. An educated guess would be .16 gauge. 1/8" should be fine.
Old Nov 10, 2006 | 10:20 AM
my86z's Avatar
I see that you're in NC as well. Where at?
Old Nov 10, 2006 | 10:32 AM
I'd go at least 1/4 inch.... thicker isn't any more difficult to fab, and it's going to be stronger. You will need that especially if you will be doing any auto-x or racing. Look at the stock mount... it's not flimzy... so don't make a custom one weak.
You should also be aware that sold diff mounts make hella-noise.... you hear road and mechanical noise a lot more.
Old Nov 23, 2006 | 01:46 AM
cheezmonta's Avatar
Couldn't resist pimping a pic of my home made diff mount. Not bad for about $8 and some time with a tape measure and drill press. 1/2" angle Iron is MORE than enough for ANYTHING I can imagine ever throwing at the car.
Pic is of a test fit which is why there's missing nuts and nothings tightened down.
Daemione
Mar 15, 2015 05:21 AM
Pez
Dec 9, 2014 02:54 PM
LemonHead
Mar 12, 2012 10:57 AM
zcarron
Dec 9, 2009 03:07 PM
majajason240
Jun 2, 2003 11:14 PM
