Turn signal/head light indicator problem
Old 07-08-2005, 02:53 PM
JDsmash's Avatar
For some odd reason right turn signal light is flashing faster ( and the Front right is flashing dimmer also). I checked all my bulbs and they are good. I am not sure how to solve this problem and I dont know where to start. Another thing too is that the "headlights" inidcator on my dash no longer turns on when I turn my lights on. The indicator lights still function becuase they still turn on when i have the keys in "on" but havent started the engine.
Any suggestions as to what might be my problem and possible solution would be great~ Thanks
JDsmash is offline
Old 07-08-2005, 06:55 PM
Ryan82ZX's Avatar
Well, i would check your ground wires up by your lights. I have to wiring problems all the time on trailers at work, and most of the time it is simply a grounding problem. It might sound funny, but the last ground wire I fixed on one of our trailers it was in the brake system. When we hit the brakes the headlight would come on, so wiring can be really weird!
Ryan82ZX is offline
Old 07-10-2005, 09:01 PM
JDsmash's Avatar
I am still very new to cars and appreciate the tip, but since i am still a mechanical newby do you think might be able to give me a break down as to how I get to the ground wires? ( if its too much trouble maybe any other information as to how i might start would be fine )
JDsmash is offline
Old 07-12-2005, 11:01 PM
AZ-ZBum's Avatar
First, are all the lights working?
Most often, it's a bulb that's out.
AZ-ZBum is offline
Old 07-16-2005, 12:40 AM
JDsmash's Avatar
Originally Posted by JDsmash
... I checked all my bulbs and they are good....
yep yep, I even tried swapping out some bulbs for fresher ones.
JDsmash is offline
Old 07-16-2005, 06:33 AM
Ryan82ZX's Avatar
I would go out and buy a chiltons or FSM (factory service manual). They will give you wiring diagrams that will tell you where the ground wires are located. If i get the time I will try and scan some and send them to you. I am pretty busy though. I will tell you that there is usually a ground wire that comes off the battery and mounts to the body under the hood and a couple more on the engine. Let know what you find out!
Ryan82ZX is offline
ohsemix
10-13-2014 12:27 PM
z31Nightshift
12-11-2013 06:56 PM
brad101010
03-17-2006 09:48 AM
fuzzo
09-13-2003 07:30 PM
zbest91tt
10-26-2002 03:36 AM
Quick Reply: Turn signal/head light indicator problem
