aftermarket power antenna install
Old Feb 12, 2007 | 06:13 AM
Turbo86's Avatar
anybody install an aftermarket power antenna ... I need to pick your brain
Old Feb 12, 2007 | 06:49 AM
so.... yeah.... whas the problem?
Old Feb 12, 2007 | 08:58 AM
Turbo86's Avatar
theres 3 wires (1) green/blue (2) green/white stripe (3) yellow ... the service manual shows 1 positive and 2 negative makes it go up ... then it shows 2 positive and 1 negative makes it go down and the yellow wire ? ... I have a red wire thats supposed to be the hot all the time wire and a green wire thats hot when I turn on the radio and a black wire that I'm supposed to ground with a screw ... my logic was the down position was the one that's the off state so do I splice the red wire to the the (2) + wire and the green wire to the (1) - wire and when the radio turns on they switch to 1 + and 2 - and the yellow wire is not used? ... I thought yellow wires were hot wires?
Old Feb 12, 2007 | 11:49 AM
AZ-ZBum's Avatar
get a volt meter and test the wires.
turn the car off and check each wire for 12V. = hot wire.
then, turn the car and stereo on and check for 12V. = signal wire.
carfanatic
Nov 11, 2009 09:34 PM
maxxypearl
Sep 30, 2009 08:31 PM
duowing
Sep 16, 2007 02:58 PM
colin_barnes
Sep 29, 2005 04:52 PM
1SIKZ
Apr 8, 2005 05:14 AM
