WTB Swastika lugnuts any and all
Old Nov 14, 2005 | 12:01 PM
drift9's Avatar
WTB Swastika lugnuts i need 16 of them let me know how many you have and how much you want for them. email rapperformance@hotmail.com
Old Nov 14, 2005 | 12:16 PM
For the 280zx turbo? They are the same lug nuts as the n/a rims.
Old Nov 14, 2005 | 06:40 PM
drift9's Avatar
im not sure about that but if they are i still need them
Old Nov 14, 2005 | 09:27 PM
which part are you not sure about? The lugs or rims?
Old Nov 14, 2005 | 09:55 PM
007max's Avatar
From NY to AZ
step 1: go to auto-parts store
step 2: buy lugnuts
step 3: ....
step 4: profit?
Old Nov 14, 2005 | 10:11 PM
lww's Avatar
lww
Head Muckraker
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 15, 2005 | 08:03 AM
but aren't these old Nissan mag wheels unique in that to be seated properly they require Nissan OEM lug nuts? I've heard this many times before.
But the lugs should be easy enough to find used.
Old Nov 16, 2005 | 10:32 AM
drift9's Avatar
Bingo i have after market nut they dont make the wheel seat correctly because the diameter of the outside of the shank is to small,therefore allowing play,slop when mounting the wheels,ie out of balance wheel. the dealership want 7.00 a nut x16 nuts 112 dollars, way to much for some ****ing lugnuts! thats why i wondered if anyone here had any at least that way it would only be maybe 60 dollars.
Old Nov 16, 2005 | 10:36 AM
Have you tried the junk yards / wrecking yards??? I think the Pick n Pull charges $.50 to $1 for lugs.
Old Nov 16, 2005 | 03:33 PM
007max's Avatar
From NY to AZ
here you go i think these are the ones you want
http://cgi.ebay.com/ebaymotors/LUG-N...14124008QQrdZ1
Old Nov 16, 2005 | 03:46 PM
those don't look exactly like my factory alloy lugnuts. You want old school Datsun NUTZ, not Nissan truck ones.
Even with the factory nuts, I've heard if you want it really centered, you need to use two acorn nuts and gently secure the wheel on. The tapered shape of those lugnuts will center the wheel. Then tighten down two of the shank style nuts. Remove the acorn lugnuts and install the remaining two alloy style nuts.
Old Nov 16, 2005 | 05:24 PM
careful... those aren't the same as the 280zx.
Nissan truck lugs:
280ZX lugs:
Old Nov 17, 2005 | 08:37 AM
007max's Avatar
From NY to AZ
whoops i thought those looked exactly like my stock lugs
thank god my Rikens run regular lug nuts without the shank
Old Nov 18, 2005 | 03:04 PM
drift9's Avatar
problem solved 2.48 a piece at avenue imparts
WanganDevilZ
Oct 21, 2013 10:51 PM
83turbo280zx
Mar 3, 2013 10:58 AM
Crazypunkerguy
Jan 23, 2012 06:07 AM
WanganDevilZ
Oct 9, 2011 05:03 PM
Carl's Z
Mar 25, 2007 06:29 PM
