Windshield wipers
Old Oct 20, 2007 | 12:03 AM
raythenegr0's Avatar
Poor kid, no ruler
Windshield wipers
So today I got a muffler fabricated for my 280zx, makes a big difference now with the noise. Anyways, my car finally seems to be coming together...However, my wipers died out on me, I doubt its the motors for it. Probably wiring or a fuse, it was raining and I just got home so I didn't touch anything.
Any ideas?
Old Oct 20, 2007 | 12:57 AM
thxone's Avatar
Yeah...I have an idea, could be the wiper switch. They tend to burn out for some reason. Might be a fuse also.
Old Oct 20, 2007 | 12:21 PM
plainwhiteZ's Avatar
alas my wipers just went out last night after fixing a faulty drivers seatbelt. I checked fuses last nigh and they wee fine. to check yoursjust switch your cabin light fuse and wiper motor and if your lights still work you know your fuse is good and the problem lay somwhere else.
next I'm going to use a voltmeter from my friends house to measure the current at the motor to see if it is getting any juice or not.
Question: when you say wiper switch do you mean the actuall **** or are you referring to some electrical component? where do you get new one?
Old Oct 20, 2007 | 01:04 PM
Poor kid, no ruler
Also my tach seems to have completely died on me as well as my fuel indicator.
Thoughts?
Old Oct 23, 2007 | 11:15 AM
no ideas for tach and fuel indicator but as fo your wipers I just fixed mine... kinda.
How did your wipers stop? if they got stuck engauged then it is the motor. try turning them on and wiggling the wiper arms there is a good chance the motor is dying and loosing power, but not dead yet. if they start up keep them running and oil up all the joints beaneth the black grille above the hood that should put off replacing the motor for at least another rauiny season.
if they stopped in the down position and wont engauge again then it is probably the switch. make sure to check the fuse though.
Old Oct 23, 2007 | 01:50 PM
Poor kid, no ruler
Actually I wiggled around the fuses and the wipers work again.
My fuel indicator and tach are still dead though...
Old Oct 23, 2007 | 02:35 PM
If your fuel gauge, and tach are still dead. There is a chance your temp gauge isn't working either. This sounds silly, but tap on your dash above the gauges. I had this problem with all my Z's. Sometimes it would happen, and I would tap it just right. And the tach, fuel, and temp would work again. Really weird, but yeah man try it and see. Or if that don't work, unplug all your gauges. Basically remove the passenger kick panel. Unplug all the plugs on that side to the fusebox. And your gauges might work again. It worked for me good luck. And let us know how it went.
Oh yeah do make sure you plug the things back in. lol I forgot to mention that doh!
Slowz
Feb 14, 2014 10:04 AM
JAyD_917
Dec 2, 2013 05:38 PM
vitaminZ
May 28, 2010 11:14 AM
craigerd2
12
Mar 20, 2003 04:27 AM
BackseatZ
Apr 5, 2002 03:04 PM
