What kind of gas do you guys run?
Old Mar 21, 2004 | 10:08 AM
smartman3000's Avatar
I personally only run 87 BP Amoco gas. With these lower compression engines (8.8:1) and aluminum heads, I wouldn't think there would be any problem with baseline low octane fuel. Am I right? Would it really make a difference whether there was 87 in it or 92?
Thanks for your help,
brian
Old Mar 21, 2004 | 10:21 AM
FastZ's Avatar
I always run 93. I personally think it burns cleaner. Cause when I bought the car it only 87. The carbon build up was crazy, even after a tune up it clean up a little bit but not a lot. So I changed to 93 and after about 3 tanks it was noticably cleaner. I also saw about a 3mpg increase between the 87 and 93. But that is just my opinion.
Old Mar 21, 2004 | 10:26 AM
Carl's Z's Avatar
I always stick to Chevron. I like to get the high grade stuff as much as possible, but with the prices lately, I've had to stick with 87. Still, I think it's the Techron that makes my car happy...
Old Mar 22, 2004 | 12:00 AM
I have to run 87 octain just to keep my car from pinging due to carbon buildup from running high octain fuel in the past! I really don't believe that a tank of higher octain gas cleans anyting inside your engine. These car do have low compression and I used to be able to run 85.
Old Mar 22, 2004 | 07:47 AM
Bleach, you might want to try running a decarbonizer in the engine, or pull the plugs, spray each cylinder with carb cleaner, change the oil (it does thin it out), and take it out and really lean on it. That's what we call in the industry blowing the cobwebs out of it. Get on that thing like a hot rod and it'll break all the carbon loose and shoot it right out the tailpipe. Try it and it will help your engine.
Old Mar 22, 2004 | 11:32 AM
Ok, cool. I'll try that. I usually drive the car pretty easy but "clean her out" at least once per drive while entering the freeway. ...or at random when I feel like it. The Z is parked for now. The transmission died... plus I need a new timing chain I think. 218K miles on one chain?
Old Mar 22, 2004 | 03:03 PM
Yeah, that's a common trick known to those only in the industry. Put something in it to clean the carbon, take it on the road, and beat the sh** out of it. Take it on a country road and really get on it for a good 10 or so minutes to get the engine nice and hot and blow all the crap out the tailpipe.
P.S. that's great mileage on a timing chain, others would wish to be as ucky as you.
Brian
Old Mar 24, 2004 | 09:54 PM
Carl's Z's Avatar
That's like mine. I've got 250k+ miles and an old nissan Z tech told my my chain was in good shape, so I figure someone got to it sometime or another. Sure would be nice if the previous owner(s) kept records like I do!...
wide z31
Aug 10, 2008 04:40 AM
FubarI33t
Sep 17, 2006 07:57 PM
yobobrox
Jun 29, 2005 07:04 PM
phrozen209
34
Jan 21, 2005 10:24 AM
lil_racer_tony
Aug 2, 2002 01:23 AM
