valve stem seals
Old Mar 10, 2009 | 08:49 PM
ellisdaddy917's Avatar
valve stem seals
i have a 79 280zx with bad valve stem seals... im waiting on the new head gasket set to get here but i was wondering if anyone had any tips that may help me... iv taken heads off of several cars but most were mpfi and the ones that werent mpfi werent overhead cam engines... iv also never worked with a timing chain before
Old Mar 10, 2009 | 08:53 PM
Tips on removing the cylinder head? Buy the Haynes manual. Seriously... don't touch the car w/o one. All the steps are in there.
It's fairly simple, just time consuming, especially the first time (for you & the car). The crappiest part is getting the exhaust disconnected from the manifold. After that, just disconnect all hoses, shove a 1" wide wood block down the inside of the timing chain, remove the cam gear, and remove the head. There's also several threads here talking about head removal... search em out (I would for you, but I'm doing homework).
Old Mar 10, 2009 | 08:54 PM
straight hate's Avatar
Valve spring compressor comes in handy, and dont loose the little pieces!
Old Mar 10, 2009 | 08:58 PM
yeah i have a chiltons manual... just thought maybe there was some extra tips that they didnt include in my manual
Old Mar 10, 2009 | 08:59 PM
A magnet.
Old Mar 10, 2009 | 09:05 PM
Just do not let the timing chain loose between the guides... otherwise the tensioner will pop out and you'll have to remove the timing cover to reset it.
Also set the motor to TDC on cyl #1 and mark the timing chain & sprocket... then you'll have no confusion when putting back together.
Old Mar 13, 2009 | 09:33 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Make sure that wood block is secure too. Dropping the timing chain sucks!
Old Mar 13, 2009 | 04:14 PM
S.n.a.f.u.!
Old Mar 13, 2009 | 06:53 PM
sho_shane's Avatar
"S.N.A.F.U" What?
Old Mar 14, 2009 | 11:02 AM
pete8717's Avatar
Try checking out this for removal of the manifolds. It helped me a lot.
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/how-do-your-intake-exhaust-gasket-18779/
Old Mar 15, 2009 | 12:03 AM
do the valve guides have to be removed to get the valve stem seals out?
Old Mar 15, 2009 | 09:44 AM
pete8717's Avatar
No. Just like every other head you just remove the valve springs and you can just pull them off.
blackweb
Jan 7, 2013 06:42 PM
melloyello
Nov 1, 2004 10:49 PM
quansta
Nov 28, 2002 03:28 PM
Colin72Z
Apr 2, 2002 04:11 AM
