Two questions:
Old Mar 25, 2009 | 04:16 PM
IRideRome's Avatar
Two questions:
Everybody suggests checking the AFM, but how exactly is this checked?
I have taken mine out and it was grime-free inside.
Old Mar 25, 2009 | 05:29 PM
Ratfink's Avatar
Hoov for Pres!
Is the car running?
If it's running the best way to tune it is with a air fuel ratio gauge on a dyno. Or you can do your best with the seat dyno and check your plugs all the time.
There is a section on rebuilding AFM's. Pretty straight forward and simple.
Old Mar 25, 2009 | 05:51 PM
Rome, have you checked this yet? https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/js-how-rebuild-your-afm-15277/
Old Mar 25, 2009 | 06:22 PM
IRideRome's Avatar
The car is running, however unless I use the gas pedal to keep the RPM's at 1000, it dies. I've already replaced the oxygen sensor, and just took out the TPS and cleaned the corroded contacts, since an ohm meter said it wasn't working correctly. I have now put that back in my car, and adjusted it correctly. This however did not solve the idle problem.
Any suggestions on what it could be? I'm thinking about ordering a new CHTS, does anybody know what else these could be called, I couldn't find it on blackdragonauto.com
Oh and thanks for the replies.
By the way, the car had been running perfectly for the last 1-2 years I've owned it. This problem came out of the blue.
Old Mar 25, 2009 | 06:25 PM
What's the timing set to? Have you checked the spark plug tips to see if all 6 cylinders are firing the same?
One trick to see if the AFM is working correctly is to open the black cover & push the flapper lever w/ your finger (very slightly) to see if the engine speeds up or slows down.
Old Mar 25, 2009 | 06:36 PM
IRideRome's Avatar
The car had been properly timed a few months back, so I'm assuming the timing is fine. I've recently changed all the spark plugs and wires, so there shouldn't be any problems there either.
I think I'm going to go try that AFM trick.
Old Mar 25, 2009 | 06:41 PM
could also be a vac leak, and what about your idle needle? is it adjusted good? when did it start dying? did you do anything to it/touch anything? or just start it one day and it wouldnt idle?
Old Mar 25, 2009 | 06:43 PM
IRideRome's Avatar
When I first got the car we went through and replaced all the vacuum tubes.
What do you mean adjusted good?
A few days back, I was driving home and it randomly did started. I had not been inside the engine bay recently before it happened.
Old Mar 25, 2009 | 06:50 PM
there's an idle adjustment screw near the throttle body, check it out! also, when you did the timing you remembered to tighten the dizzy back up right? lol. might be worth giving it a wiggle to check.
Old Mar 25, 2009 | 06:52 PM
IRideRome's Avatar
Yeah I've tried adjusting the screw, doesn't change the fact that it won't idle unassisted though. That's a good idea since I'm prone to forget things haha.
So you say i have to give it a wiggle? which one should I present the car with.
Old Mar 26, 2009 | 01:36 PM
IRideRome's Avatar
Just to update you guys on the situation, I just finished doing the AFM rebuild, just moving the carbon track, since I don't have the necessary equipment to complete the rest of tune.
After that, I filed the corrosion of off every connection I could see, and sprayed it out with electronics cleaner.
So I went to start my car, and it still displayed the same problems.
But when I walked out behind it, this soot like substance had covered the ground behind my exhaust pipe.
What is going on?
I suppose it is running way too rich now.
One more question, is this the location of the cylinderhead temperature sensor? I can't seem to find it in my chilton manual (came with the car, would have got a haynes if I could. Is that the location of the CHTS? Nestled between the two spark plugs?
Old Mar 26, 2009 | 03:17 PM
ellisdaddy917's Avatar
my 79 280zx did the same thing... all of the sudden one day it just quit running right and wouldnt idle... i pulled my spark plugs and realized they were coated in oil... i also had those spots all over the driveway behind my car... turned out to be the valve stem seals
Old Mar 26, 2009 | 03:52 PM
check compression to be safe, and yes thats the CHTS
Old Mar 27, 2009 | 03:05 PM
IRideRome's Avatar
Is the cylinder head temperature sensor and coolant temperature sensor the same thing?
Old Mar 27, 2009 | 06:38 PM
i still ask myself that question. like they are obviously different things! but im not sure if they are the same part/part number haha.
Old Mar 27, 2009 | 11:39 PM
rogerz's Avatar
Grumpy & Helpful
chts and temp sensor are two different animals. chts has two pins temp sensor only one. temp sensor on the front of the engine by the thermostat.
Old Mar 28, 2009 | 02:17 AM
yeah thats true, theres another one in the coolant neck im thinking of though, cant recall it. maybe im insane,i havent looked at an S130 motor in about a year now....
Old Mar 28, 2009 | 09:34 AM
IRideRome's Avatar
Hmm, if they are two different things then it looks like I'm stuck with my order from the zstore.
It was kind of expensive for the CHTS from there, but the coolant temp sensor from rock auto was like $30 dollars less expensive, so I thought I was getting screwed there, if they were indeed the same.
I'm kind of mad at the zstore though, when I ordered, no where on the site did it say that it wasn't in stock, and then I get the confirmation email, and I'm going to have to wait another week for them to get the part in before they can ship it to me.
Old Mar 28, 2009 | 09:59 PM
The motor will have either a CHTS or a Coolant Temp Sensor, but not both. There's also the thermotime sensor for the Air Regulator. All three of these sensors look the same:
http://www.courtesyparts.com/engine-...-p-569132.html
Different than this:
http://www.courtesyparts.com/water-t...-p-569133.html
Old Mar 29, 2009 | 04:55 PM
IRideRome's Avatar
Update: Checked compression, seems fine.
I'm stuck waiting a week for a CHTS.
Update: Just went to start up the car, it ran perfectly for a minute, then the idle dropped from 1000, to 500, but unlike before, it did not stall and ran for five minutes until I chose to turn it off. The only problem is it's running extremely rich. How do I adjust that?
Also, turning the idle screw does nothing to change the idle.
Old Mar 29, 2009 | 09:36 PM
IRideRome's Avatar
So I just realized I hadn't cleaned and filed the thermotime sensor connection, so I'm leaning over the car cleaning it and heard a snap.
I look down and see this:
Ah
Old Mar 29, 2009 | 09:39 PM
Good times there...
Old Mar 29, 2009 | 09:48 PM
IRideRome's Avatar
Being clumsy offers little, to no, help when trying to repair a car.
Old Mar 29, 2009 | 09:51 PM
cracked charcoal canister = vacuum leak. i say eliminate it. its worthless imho anyways.
Old Mar 29, 2009 | 09:52 PM
EDIT ^^^ word.
Meh... it's not a super important vac line. Just cap both ends for now.
