trying to get a feel of what noise is normal and what's not
Old Apr 15, 2009 | 06:26 AM
280zdude's Avatar
I am new to the 280z world so forgive my ignorance. But I noticed this morning that there is a slight hum or whine in the rear of the car. I wasn't sure if this was normal due to the low gears or if there was a rear end problem.
It is automatic and I noticed the noise during all phases of driving. Is this normal?
Old Apr 15, 2009 | 06:47 AM
Just to clarify, you have a 280ZX not a 280Z right?
Did this sound just appear, or has it always been there?
Old Apr 15, 2009 | 06:51 AM
280zdude's Avatar
You are right, it is a ZX. As far as the noise goes, the thing is i have owned but for a few weeks and this is only the second time I have driven it, so i don't know if it has been there all along or not.
Old Apr 15, 2009 | 07:11 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
If its a low hum like a vibration then it could be a u-joint...
a hum CAN signify the rear end is wearing away. if its only a little. i wouldnt worry about it, maybe check and change the diff fluid (if you can they really retarded up the fill plug on these cars) and see what happens. i suppose it could also be from a wheel bearing though so i would try to make sure its coming from the diff and not a wheel first. if it is infact the diff. not much you can do other than what i said and listen for any other odd noises it might be making or if it gets louder.
if it isnt a hum and is a vibration then it could be something else like someone above me said, but usually it will be accompanied by a clunking when starting off in first or going from reverse to first or vise versus
Old Apr 15, 2009 | 10:49 AM
BlueKitsune's Avatar
Intrawebz Wizard
What about a clunk on every gear change going forward, or when just hitting the gas going forward?
Might want to check your diff mount to see if its worn out, then you could really hear the diff
Old Apr 15, 2009 | 11:32 AM
280zdude's Avatar
Didn't hear any clunking.
Old Apr 15, 2009 | 12:28 PM
i didnt mention that because if there was clunking i would have assumed he would have mentioned it. and he just there verified that thought. probably a bearing, but if you can change the diff fluid and hope for the best. also like i said, try to make sure it isn't a wheel bearing thats making the noise.
Old Apr 15, 2009 | 02:20 PM
Intrawebz Wizard
Does the hum kinda sound like a buzz? Or does it sound like a metal ball rolling on a thick sheet of metal?
Old Apr 15, 2009 | 05:08 PM
We need a GOOD video or sound clip if we're ever going to get anywhere. It's pretty hard to diagnose a sound problem by typing it out in a forum.
Old Apr 15, 2009 | 05:29 PM
true... but im not worried about it if its LIGHT like he says. probably a worn bearing. hopefully not one fallin apart.
Old Apr 15, 2009 | 07:33 PM
280zx2by2's Avatar
Haterade by da gallon!
if its a whine when your slowing down thats just the sound of these old trans... get used to it
Old Apr 16, 2009 | 04:51 AM
280zdude's Avatar
^ ^ ^ That is the sort of info I am looking for. That is exactly what it sounds like, but it also does it when you speed up. Same thing????
Old May 15, 2009 | 05:32 AM
septerra's Avatar
ZX2802
hey guys. I been experiencing the same kind of noise at the rear end. Its like a vibration when accelerating from every gear. It suddenly wasnt making that noise today when I was driving home and it felt so much better. It actually felt like I had more power, but that could be just because I could hear the engine better without the vibration making me feel like i got some extra power.
Really i got no experience, so any help appreciated.
Old May 15, 2009 | 03:43 PM
ZBRICK's Avatar
Only driven 2 times - drive more
Riz Z Speed
Polls
26
Nov 25, 2010 09:42 PM
thxone
Sep 21, 2006 06:44 PM
NismoPick
Oct 5, 2005 01:11 PM
Captain caveman
May 18, 2005 09:13 AM
ZCARDiego
25
Mar 18, 2004 05:20 PM
