Temperature sensor not working :(
Old Jan 22, 2013 | 07:17 AM
chris reptiles's Avatar
Unhappy Temperature sensor not working :(
ok, I wasted money already. I purchased another dash display for my 83 280zx non-turbo because the temperature gauge does not work. I checked the sensors, one problem I see 3 sensors connected to the thermostat housing and I'm not sure which one is the correct sensor to change. One guy told me to take a negative wire and connect it to my negative part of the battery and touch the wire to the sensors and which ever one that moves the needle on the gauage thats the sensor needs to be change. Will the problem is none is making the gauage move. I even called the guy I bought the dash from and he said he took that gauge off a running car and all the gauages was working just fine. [B]ANY SUGGESTIONS? WHICH ONE IS THE TEMPERATURE SENSOR ????[B] pepboys gave me one with two prompt then O'Reiley's gave me one that looks like a machine gun bullet lol. He said I'm suppose to take out the old one and replace it with that. Both autoparts don't know where the temperature sensor goes....does anyone have a suggestions or can you tell me which one is the correct sensor to change? All the fuses is good.
Old Jan 22, 2013 | 08:38 AM
Welcome to ZDriver!
Click: https://www.zdriver.com/forums/280zx...sensors-36716/
There are 3 sensors...
#1: Water temp sensor for dash gauge
#2: Water temp switch for the aux fan
#3: Thermotime switch for the cold start valve.
From the FSM (you should download it here: XenonS130 - S130 Reference if you haven't done so yet).
Old Jan 22, 2013 | 09:21 AM
icice9's Avatar
Super Siver & Black Stud
here's the part that you need..
Motorsport! Water Temperature Sending Unit, 70-83* Z/ZX - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
or if you want it with the retainer
http://www.thezstore.com/page/TZS/PROD/16-7110ki
top left corner
carlos48
May 14, 2013 09:38 PM
Alostael
Sep 19, 2010 09:23 PM
91Zman
Feb 16, 2006 01:29 PM
melloyello
Oct 12, 2005 12:09 AM
Tinker
Mar 25, 2003 12:38 PM
