Temp sensor issues
Old Sep 11, 2009 | 01:19 PM
TheGrimaceTab's Avatar
Temp sensor issues
hey guys i have a 1979 280zx. when i started to get the car working there was temp guage non-working i had a mechanic replace the temp sensor now it apparently is one from a Canadian model (not exactly sure if the American one was on before) as far as i can tell everything is connected correctally but the temp guage only works like 2% of the time any thoughts? i do know there is 2 wires for the American model car i have but this temp sensor only has one wire...
Last edited by NismoPick; Sep 12, 2009 at 06:24 PM. Reason: It's AMERICA not AMARICA. :)
Old Sep 11, 2009 | 02:00 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
https://www.zdriver.com/forums/280zx-performance-technical-79/81-temperature-gauge-29069/
Old Sep 11, 2009 | 02:02 PM
skib's Avatar
This facepalm's for you!
Originally Posted by audiofreak97
Originally Posted by skib
thats usually the problem, your temp sensor is on the front of the thermostat housing. Its just a single bullet connector, just double check its connected and clean.
Old Sep 11, 2009 | 04:04 PM
thanks, its just that theres no wire diagram in my manual also will a canadian temp sensor work on us model it seems 2. dew 2 the fact it works very rarely
Old Sep 11, 2009 | 04:37 PM
skib's Avatar
the single bullet connector temp senders (that are the one for your temp gauge) are all the same, you can get one out of any L6 and itl work fine.
make sure the sender is good and your connections are free of corrosion and that the ground is good.
Old Sep 21, 2009 | 12:54 PM
hmm my temp sensor is all hooked up and clean tested working... it still does not work most of the time. however recently after reconnecting everything it seems to work well when the headlights are on... is this even possible that the headlights/fuse/wiring can effect temp sensor functionality....
Desert Rat
Jul 20, 2015 01:37 PM
steve
Nov 8, 2011 03:27 PM
Niku-Sama
Dec 22, 2008 02:24 PM
one_fast_300zx
Oct 10, 2007 12:43 PM
Johnny Z
Mar 16, 2005 06:17 PM
