Sudden loss of oil pressure at Idle
So I have a bad Bcddc valve lol. So every day I adjust my Idle. I'm either at 400 rpms or 2500.Very annoying at lights. Noticed at 500 revs my oil pressure dives to 0. On the gauge. Soon as I rev back up the oil pressure goes back to normal. I'm starting my winter to do lists not sure if this could be oil pump related. Figure I'd see if anyone had this issue???
Also plug the vacuum line going to the BCDD, that might stop your idle issues unless the spring in the BCDD if broken and just letting any amount of air in.
all it does is stops oil from being sucked in through the valve guides when the engine is at low throttle but high RPM, like when going down a hill.
Yeah sometimes my pressure doesn't read right. The needle will be too low when I am on the freeway. lol I am sure it is either the plug or the unit itself. I haven't got around to messing with it much. Have some other important things to take care of.
blckdrgn
Apr 9, 2012 07:55 PM
chriswf
Oct 1, 2010 09:10 AM
