Starts great, idle drop/choke after 3 mins
Old Apr 11, 2017 | 08:21 PM
TrashMobile's Avatar
1983 280zx, non turbo, 5spd
I'm at my wits end with this! Car cranks and sounds great! Once car starts to warm up, after about 3 minutes, the idle drops. When I hit the gas it almost chokes out bc it's running so rich.
Here's what we've replaced so far:
head coolant temp sensor & rewired to ECU
thermotime sensor
ported vacuum switch
new distributor
fuel pressure regulator
injectors
CSV functions fine
Unplugged O2 sensor & it didn't make a difference
Any suggestions? This is my daily driver and I'm about to just climb into it and set it all on fire, lol.
Going to clean the AFM tomorrow and see if that helps. It's def something temp related, I just can't figure out what 😰
Thank you in advance for your help.
Old Apr 12, 2017 | 08:50 AM
Welcome to ZDriver!
Are you on the 280ZX Drivers Facebook group? Seems like there was a post about this there too...
Have you OHM tested the CHTS through the ECU connection? Just because you replaced it doesn't mean it's working. Test it.
Have you done the Air Regulator pinch test on the hose between throttle body and air reg? It should lower rpm when cold, do nothing when warm.
Have you checked timing?
Old Apr 13, 2017 | 02:26 PM
Welcome to ZDriver!
Checked the ohm tested the sensor & it works fine. Maybe its faulty? May send it back.
Going to need new hose to pinch that regulator connection off, it's so stiff it feels like cement 😂
the timing is good.
-now it won't even crank
Last edited by TrashMobile; Apr 13, 2017 at 03:24 PM. Reason: Additional information
Old Apr 13, 2017 | 08:54 PM
Won't crank? Or won't start? If it won't crank, you have battery problems. If it cranks but won't start, pull the plugs to see if it's actually flooded (wet plugs) or no fuel (dry plugs).
DanAstro
Mar 13, 2015 09:58 AM
scottw
Sep 21, 2014 06:39 PM
teamadidas
FS: 300ZX (84-89)
Apr 15, 2002 10:23 AM
teamadidas
Apr 15, 2002 10:20 AM
Z_Ferrari
Mar 19, 2002 08:22 PM
