Starting to put the motor back together, need input
Old Nov 9, 2012 | 10:00 AM
  #26
Rest up - you'll need your strength to bed those bolts in if you can't get your hands on a bottoming tap hahaha (The hahaha is the shortened version of a long disclaimer which says don't actually do that ;P )
Old Nov 9, 2012 | 02:27 PM
  #27
WanganDevilZ's Avatar
The Emblem Thief y0!
Oh no, I went and got a tap and ground it down and made sure it threaded in before venturing, I feel better as of this afternoon and stumbled into the garage and got all of the threads ungunked, just waiting for more actual time (Still woozy) to be able to spend and concentrate out in the garage
Thanks for the suggestions, I had a regular tap but it was bottoming out with the starting threads, so I got one to 'break'
I'll keep it in the misc. tools drawer.
Old Dec 2, 2012 | 08:50 PM
  #28
Got my motor over to my friends shop to have a mechanic put it together so that I wouldn't screw anything up.
We were checking the crank to check if it turned, and it gave us a lot of resistance, so we loosened the main and rod bolts, and it started turning like it should. We re-torqued the bolts in the right order, to the right specs, and it wasn't as tight, but it was still kind of iffy. Plastigauge revealed that the bearings were also, in spec, and that nothing was an issue (This is based off of the rear rod bearing), the rest of the rods and crank bearings will be tested tomorrow.
I do have ARP rod and main bolts installed currently.
Any idea what would be causing the crank to not turn freely?
Old Dec 2, 2012 | 10:19 PM
  #29
Gotta plastigauge them all...
Old Dec 3, 2012 | 03:08 PM
  #30
That comes soon, his hours and mine are completely different, I'm off to bed just as he's getting up in the "Morning"
Meh
Hopefully he has good news
Old Jan 10, 2013 | 07:01 PM
  #31
Update? No progress, longest rebuild in the world here. Should have paid someone back in 2009, it would have cost less.
I'm getting discouraged, as with all the other issues in my life regarding my job, classes, and the possibility of actually moving forward with my life, I've barely been able to make a dent in the Z. I thought about moving forward in technology and getting a Z32, but that wouldn't be better on my finances, regarding maintenance. I've looked into possibly getting a DD and having the Z, but why pay the extra registration.
Life really sucks when you have no hobbies, nothing interests you, and all your friends have moved away.
TULSA, Y U NO HAVE Z PEPL?!
Old Jan 10, 2013 | 08:41 PM
  #32
Don't buy a Z32 in your emo state of mind. And finish the block yourself. If you have a quality torque wrench you can get it all back together by following the FSM.
Old Jan 10, 2013 | 09:32 PM
  #33
I borrowed a Matco Torque wrench from work specifically for this undertaking.
Old Jan 10, 2013 | 09:38 PM
  #34
So get 'er done...
Old Jan 19, 2013 | 01:13 PM
  #35
The rod bearings look like they have a bit of wear on them, looks kinda like they got tightened too much, should I just go ahead and replace them just in case? On a zero mile motor, better safe than stranded.
Old Jan 19, 2013 | 02:45 PM
  #36
Pics?
Builds become nightmares when you don't follow the FSM... You aren't supposed to rotate the crank when plastigaging them. Only rotate when you have applied assembly lube.
Old Jan 19, 2013 | 03:12 PM
  #37
Pics?
They originally were overtightened, untighened, then torqued correctly. Then they were plastigauged one at a time, I don't think all of them have been checked yet but a few of them have pretty significant wear spots on them, pics later this evening, I need to get to the shop where the motor is at.
And they all had been lubed, just overtorqued
Old Jan 20, 2013 | 06:40 PM
  #38
I still don't get how this happened...
So you plastigaged a few bearings, took it all apart, lubed it, overtightened, spun it a lot, then took it back apart?
I thought the reason you were doing this at a shop was because you were being supervised? (I'm not being rude, I just don't think I'm getting the whole story).
Old Jan 20, 2013 | 06:45 PM
  #39
So get 'er done...
No, they were overtightened, taken apart, plastigauged, torqued to the right specs, and it still kind of hangs up, it spins a lot more freely, but initially it's very hard to turn, but once you get it turning, it's easy, and yes, everything was lubed correctly
Old Jan 20, 2013 | 06:48 PM
  #40
Before you buy another set of bearings, you need to plastigage EVERY bearing. You might find that one or two are out of spec and need to be machined, requiring a diff size bearing.
Old Jan 21, 2013 | 02:14 PM
  #41
Z32 might be forward in technology but pray you never need to work on it!
Old Jan 22, 2013 | 08:34 PM
  #42
Taking the motor completely apart on Thursday to check all tolerances once more, also with help from the machine shop, who have been very gracious to lend assistance.
Maybe someday, I'll have enough monies to afford a 350z or so-on, and be able to have two cars...
Old Jan 23, 2013 | 07:37 AM
  #43
ThaPimpShrimp's Avatar
Maybe you'll have saved enough to afford whatever their anniversary "240z" will be!
NISMO Stuff: 2014 240Z Confirmed!!! (sort of)
Old Jan 23, 2013 | 01:11 PM
  #44
They just need to make the 240z again, carbs and all.
Old Jan 24, 2013 | 07:22 PM
  #45
Triple sound wicked and I love 'em on my 240Z but EFI is really the way to go...
Old Feb 10, 2013 | 02:14 PM
  #46
Trying to swap out gas tanks, old rusty one coming out, nice clean one going in, along with like new fuel level sending unit.
Bolts on tank straps won't come undone, been soaking in PB blaster all night and day, getting re-soaked every 2 hours or so
Crowsfoot almost rounding them out, can't get long enough socket.
Ideas?
Old Feb 10, 2013 | 07:52 PM
  #47
Couldn't get the nuts off, even after soaking in pb blaster, and even after rounding one of the nuts, I ended up just grinding the bolts.
Straps are okay, just need to get new bolts. More tomorrow.
Old Feb 11, 2013 | 03:05 PM
  #48
Nissan didn't have any bolts. Period. They don't make them anymore, and there isn't a dealership that has any.
Does anyone have any un-molested gastank strap bolts they can ship to me?
Old May 9, 2013 | 04:06 PM
  #49
Allllright!
Time to get the Z out of the garage now that it's warm outside.
I guess it's the same problem it had the last time I drove it.
Between about 1400-2200 RPM it kind of stutters and feels like the timing is off or it's missing. However, after 2,200 it feels normal and doesn't have any hesitation, feels like a normal car.
Tech Team Leader at work suggested the TPS or MAF, sound right? I have a few of these laying around my garage.
Old May 13, 2013 | 08:24 AM
  #50
Niku-Sama's Avatar
eff good grammar
MAF? too new
Air flow meter, AFM...
random thought, did you hook the EGR back up? if you did unhook it from vaccum and cap tat line off when you drive and see if it does the same thing.
i have the same problem with mine if the EGR is still hooked up to a vaccum source, unplugged it runs fine, but mine hasnt been rebulit
cbaumy34
Dec 28, 2012 07:02 PM
the_journeyman
Nov 20, 2012 01:31 PM
Etherealwolf
Oct 3, 2011 05:36 PM
Code-Red
Aug 18, 2011 06:36 PM
ZXT83
Jan 10, 2010 07:42 PM
