Springs? And Things
Old Aug 7, 2005 | 12:11 AM
81 Black L28E's Avatar
Springs? And Things
Where is everyone today ?????? Well its off to the auto parts store for more goodies ..
this time it will be ....
AT trany cooler
and lines
Some trany oil
Tie downs
40w forty ...oil change time
spark plugs
New rate and alt will be installed in the moring
along with these goodies
Time to cool her down some and
make more spark more I hope
I need to do touch ups on the paint
Also what will happen if i cut one coil out of each spring ?????
I am sick of riding like a 4 by 4
Old Aug 7, 2005 | 10:11 AM
RodMoyes's Avatar
Doesn't post much...
Cutting the coils is kinda ghetto... but it will give you the look you want for a really good price... free! I've done this before and learned that a little goes a long way. Better to cut too little than too much. The rear will drop more than the front with the same amount of cutting, so... baby steps... take a little bit and see how you like it. Once you cut too much, you are screwed. You also have to let them re-settle after you put them back in the car, so don't judge the look right after re-installing them. Drive it around for a few minutes and then see what you think. I'm sure you know all the negative things about cutting your coils, so I'll skip reminding you of them. Also remember that the top rings are where your progression comes from, so the ride height on the rear will change noticeably depending on how much weight is in the back of the car... i.e. how much gas is in the tank. I'd say you want to have a pretty full tank when you do it so you'll get a good idea of how it will look at it's lowest point. Have fun and good luck. That car's coming along pretty sweet.
Rod.
Old Aug 7, 2005 | 10:21 AM
WELL i got the rate and trany colder in seems to shift better ...iam bummed they sold the chrome one so i had to get this one ....o well it works good ...i was lazy and didnt change the alt ...it would have been eazyer to do with the rate out but i will just do it with the ps removed later ....i want to go play its sunday and looks like it should be hot ....hopefuly this new used rate keeps my temp down below or on the F mark ...not above like it has been doing
Old Aug 7, 2005 | 10:53 AM
Dorifto's Avatar
Hey, Black, I've got a solution for your ***-happy Zed ...
... spring clamps.
That's right, they clamp one coil of your stock springs down onto another one below it. I bought a kit that included 4 clamps for $8.99 at AutoZone. I installed the rear clamps on my car, but I put them a little far up, so it actually didn't lower the car, just bent the spring. I"ll move them down a coil later and see just how much of a difference it really makes. I'll even throw in pics when that happens.
Peaces,
-Dave-O
Old Aug 7, 2005 | 01:13 PM
cleaned her up ....put the hood on and took her for a drive the temp never went above the F STOKED ...trany shifts smoother neven under high rpm's ...spring srings srings .....iam worryed that i will cut to much so iam going to wait ...i want to remove the springs from the gold car and cut them that way if i do it wrong i will have a set to put in and make it right ....i got to get out back and pull more parts
Old Aug 7, 2005 | 10:34 PM
Hey buddy, before I jump all in... what is the purpose for lowering your Z? Performance, or looks??? If you want a super easy solution, and a wicked stiff ride, get some front springs from a 79 - 82 300D mercedes benz & cut them down to your desired ride height, for the rear springs of your 280zx. See pic....
I did that before I got my Eibach's & they worked well.
Old Aug 7, 2005 | 10:41 PM
lww's Avatar
lww
Head Muckraker
Cutting your springs will give you looks alone.
Putting engineered lowering springs will give you both.
He's trying to get the looks without spending any money until he can get the properly engineered springs.
Going to the 300D springs would cost $$ even from the junk yard.
Old Aug 7, 2005 | 10:46 PM
icice9's Avatar
Super Siver & Black Stud
i wouldnt recoment cutting the stock springs.. some of my friends were doing that back in the 80's to thier Zs and oh man did the ride suck.. there were too low and too soft.. not a good idea... but the 300D springs might not be a bad idea..... prolly only coat you $50 buck or so in the junk yeard...
by the way.. welcome to the board NisnoPick
Old Aug 8, 2005 | 12:43 AM
by the way.. welcome to the board NismoPick
$35 is what I paid at the local Pick n Pull for those 300D springs... which around here is about the highest priced yard. Those springs are thick ace & will stop the "z squat."
Thanks for the welcome Icice9!... I've been on GOT-Z for a while & from a recent post there, remembered about this forum.... I LIKE! I LIKE!
Old Aug 8, 2005 | 05:23 AM
VenomousZX's Avatar
Eibach Pro-kit, the only way to go, as I have listed in several postings... I am trying to sell my car to no luck however my suspension is built up for autocross/racing applications & my god was it worth it! take the time & invest the $$ into the car, do not cut your springs there are too many things can go wrong with that
Old Aug 8, 2005 | 08:22 AM
do you still have thoughs sitting around i would send you some cash for them if you want i will not cut the springs that are on it now ....i mite cut the springs from the gold car............ i dont want to mess my good set up but the gold car was free so know loss if i mess thoughs up ...and yes i want the lowered look but i also want a nice flat slide ...i dought that i will get that from cut srings ......i want coil overs spendy
http://classifieds.hybridz.org/showp...p?product=1121
Old Aug 8, 2005 | 01:18 PM
I do still have them, unfortunately they are on a 280zxt that I'm selling on ebay right now.
http://cgi.ebay.com/ebaymotors/Datsu...spagenameZWDVW
I will be hittin up the Pick n Pull this week & will see if I can get another set. If I can, I'll deff just get em to ya for the cost + shipping.
Old Aug 8, 2005 | 04:49 PM
PLEASE DO ....there wont be any cars like that at my pick and pull
also will these 300D springs work in the front or just the back????
Old Aug 8, 2005 | 06:48 PM
They are just for the 280zx rears. The fronts are a much bigger diameter & I haven't found any other cars that have the same front spring size. I'm lookin tho.
KasbeKZ
Mar 29, 2010 01:03 PM
WildmaN
Mar 7, 2006 02:36 PM
CrAzY_84na
Jul 12, 2004 06:06 PM
SoloZ
Jun 17, 2003 11:05 AM
BigTDogg
May 7, 2002 09:10 AM
