spark plugs question
Old Feb 26, 2007 | 06:04 PM
BoostL28's Avatar
What can cause the spark plugs to be damped with fuel? I pulled my spark plugs today out of my 280zTurbo all six of them are charcoal black and wet with fuel. can you guys help me thanks.
Old Feb 26, 2007 | 06:06 PM
thxone's Avatar
First thing that comes to my mind is injector problem....but I am almost never right....it's probably timing....Bleach...Nismo??? what do yall think?
Old Feb 26, 2007 | 06:08 PM
skittle's Avatar
Taste My Rainbow
Running Uber Rich.... Check Your Chts, Fuel Pressure, Afm, All Sorts Of Things Can Be Causing This Issue. Just Start Off With All Of The Grounds And Electrical Connections Clean Them Up And Use Dielectric Greese.
skittle's Avatar
Taste My Rainbow
It Could Be The Injectors But Start Off With The Simple Stuff And Then Work Your Way To The Injectors.
Old Feb 26, 2007 | 06:32 PM
BoostL28's Avatar
They're not that soaked but they're not dry like a normal spark plug should look like and it smells like the raw fuel. The car has also been parked for about one year and it has 62,000mi on it. i just prchased it as my turbo swap, the car has a light wreck, i just turned it on to check that everything was ok, but it hesitates when I accelerate but it idles normal. I'm just checking right now for cracked vaccum lines, water pump, etc... just trying to get it ready for the swap. let me know any other sugestions thanks.
I'm hopping its not an injector problem.
Old Feb 26, 2007 | 06:50 PM
skittle's Avatar
Taste My Rainbow
Just Do What I Said That Should Get It Done For Ya... Crosses Fingers
Old Feb 26, 2007 | 07:06 PM
if they are black they could also be fowled out and not burning to well... id say replace your plugs, check your timing, check spark make sure its nice and bright, and maybe even have to lean out the afm a bit
Old Feb 26, 2007 | 07:19 PM
BoostL28's Avatar
OK I will work on it tommorow, I'll keep you guys posted.
Old Feb 27, 2007 | 04:28 AM
thxone's Avatar
If the car has been sitting for a year, you could have water in the fuel system keeping it from burning all the fuel.
Old Feb 27, 2007 | 07:06 AM
skittle's Avatar
Taste My Rainbow
yeah also change out the fuel pump and toss some stabil in it that will get rid of any water there maybe in the fuel.
Gingie
Mar 29, 2014 07:48 AM
Riz Z Speed
300ZX Z32 Tech Tips
Sep 28, 2005 11:36 PM
entropy31
Jul 14, 2005 01:07 PM
Seraphic
May 14, 2005 05:10 PM
MOE
Aug 16, 2004 11:27 PM
