sounds like i have a major problem again
Old Jan 21, 2008 | 11:58 PM
  #26
you might wanna re-drain your gear oil to get all those brass chunks out of the gear box.
Old Jan 22, 2008 | 12:05 AM
  #27
Niku-Sama's Avatar
eff good grammar
Originally Posted by chinesekid
so, i took my car to work today thinking i was gonna change my clutch and pilot bearing and throw out bearing.. i went to drain the tranny and no fluid came out at all!! like 5 drops... so i put gear oil in it and then everyhitng works but it makes a wineing sound on 1st 2nd and 3rd... other then that, everything seem okay... and when i was driving my "door light" came on.. and it doesnt wanna go off so my floor pannle light keep staying on
my car did the light thing the other day, it scared the crap outa me
Old Jan 22, 2008 | 08:16 AM
  #28
no oil????? yeesh bro. lol. no bueno
Old Jan 22, 2008 | 09:38 AM
  #29
chinesekid's Avatar
yea... i plug it then put oil into it and drain it again to see if there was anything comming out but there wasnt.. but does anybody know why my door light keeps comming on?
Old Jan 22, 2008 | 09:41 AM
  #30
Maybe your door switch is bad? Maybe push it a few times. Then close the door. Try it on both sides.
Old Jan 22, 2008 | 01:44 PM
  #31
yeah the door switch is bad, or your door no longer pushes on it all the way, or the wire broke somewhere. its a simple fix just play around and trace the wires nothing complicated at all.
Old Jan 22, 2008 | 02:40 PM
  #32
on my ZX it was the door latch. Loosen it and move it inward 1mm and tighten the bolts down. That brings the door in just enough to keep the switch closed.
Old Jan 22, 2008 | 03:45 PM
  #33
DriftZ83's Avatar
i thought i would add that it's probably the pilot bearing not the throwout bearing because the transmission input shaft is spinning at engine speed when in neutral with the clutch out. when the clutch is pushed in the transmission is detatched from the engine because the clutch is engauged. therfore the noise would go away because the transmission input shaft is no longer spining... if it was the throwout bearing it would make noise when pushing the clutch pedal in and pushing the throwout bearing against the pressure plate fingers because it would then have pressure applied to the bearing and spinning with the pressure plate. so i'd go with it all if your in there but make sure you replace the PILOT BEARING!!! good luck
Old Jan 22, 2008 | 04:42 PM
  #34
KasbeKZ's Avatar
Pr0n Addict
Originally Posted by nismo619
Throw out bearing.. but i got a question for every one else about clutch slipedge ? when im driving my 82 280zxt in 1st to second to third gear the rpm meter peaks with just a touch of gas.. meens my clutch is sliping right ? in time for a new clutch.. its a stock clutch from nissan its been on my car for 9 years and only put about 30,000 miles on it.. should i get another stock clutch ? or get a stage 1 or stage 2 clutch kit ?
if engine speed increases and car speed stays the same, drops, barely increases, or changes at a rate that is unusual for the conditions, that is almost definately clutch slip.
Kid: i was wondering why everyone was saying throwout bearing. that should be under little to no pressure when the clutch is out, so it would be more prone to make noise when the clutch is in. sounds like your tranny is in pretty bad shape if it didn't have any fluid... i wouldn't trust that one as far as i could throw it
Old Jan 22, 2008 | 05:44 PM
  #35
DriftZ83's Avatar
next question is how hard do you beat on it nismo619.... or the next one is was it installed correctly if you only have 30k on it....
Old Jan 22, 2008 | 08:32 PM
  #36
shhh... stop stop, we dont talk to nismo619 round these parts
Niku-Sama
Sep 5, 2008 04:29 PM
satisfied
Jan 13, 2008 10:23 PM
thetremendousti
Dec 9, 2007 09:49 AM
FubarI33t
Jan 31, 2007 08:33 PM
pearly whites
Dec 8, 2003 11:03 PM
