somethings wrong
Old 04-03-2006, 11:18 PM
chinesekid's Avatar
somethings wrong
when i take off in first gear.. my car jurks really hard.. like you know when your at a stop and you stall.. it jurks forward... it does the same when i try to take off... so i have to take off in 2nd sometimes... anybody know whats wrong?!?! engin?? tranny??.. internals?? i replace all the lines/holes.. and maybe connect one thing wrong??? anybody have the same problem or know what my problem is???
chinesekid is offline
Old 04-04-2006, 12:38 AM
Whitesmoke's Avatar
your rear diff mount may be going bad? just a thought. mine is basically gone and it will do that in all gears. not really a jerk after i get into 3rd then its more like a hesitation. I'm new to the Z world excluding Z31s so maybe it could be something else
Whitesmoke is offline
Old 04-04-2006, 01:30 AM
Taste My Rainbow
skittle's Avatar
check the mount bolts, they loosen up after a while and that can cause that jurking. I have to do that to my car as well when i get a chance. I read about that issuse on hybridz
skittle is offline
Old 04-04-2006, 11:13 PM
jfairladyz's Avatar
I doubt it has anything to do with your drive line at all. Sounds like something is loose in the engine compartment. Especially judging by your other thread. I'm too tired to put any thought into it right now as far as whats actually wrong with the car though. Put al the details you put in your other thread in this one so people will know all the problems you're having. The way you described it here it almost sounds like a driveline problem. But in your other thread you added a little more information that kind of elimates that.
Good to hear you're not selling your Z anymore though
jfairladyz is offline
Old 04-05-2006, 12:45 AM
chinesekid's Avatar
well my diff seem like its leaking.. thers all black oil around it.. like dryed up and all thick around it.. but i cant seem to take the diff cap out... its connected to the bolt on the frame.. can anybody tell me how to??..
all i did was change the lines... like vacuume lines, and fule lines.. and change my mas air fiow.. thats about it...
Old 04-05-2006, 06:56 AM
FubarI33t's Avatar
Don't pay no atation to the thick black gunk around a rear end. UNLESS you see new gear oil around it. Rear ends, oil pans, and botom of tranys tend to "Gunk Up" with thick black stuff over the year's. Just check your level, Scrape the rear end, and keep an eye out for new gear oil. And the jerkin in 1st gear, and not in secound Could mean, your 1st gear in the trany is going out... But that's just my 2 cents
FubarI33t is offline
Old 04-05-2006, 09:39 AM
what about chugging in 2'nd at low RPM's, but at high speeds? (for second gear anyway)
hoov100 is offline
Old Codger
06-01-2014 07:36 AM
BlueKitsune
06-30-2009 10:15 PM
User395
02-25-2009 07:38 PM
Captain caveman
07-22-2005 08:58 PM
ZenArcher
09-19-2001 04:31 PM
Quick Reply: somethings wrong
