Simple wiring question
Old Nov 27, 2010 | 08:29 AM
Switchtr3's Avatar
So I got the motor and tranny back in. I had stopped working on the car for a while as it was not my DD anymore and the urgency has dropped. Well I just knocked over some trees in my DD on monday so urgency is back to finish the project. All I have left to do is put the exhaust on, put the rockers back in, and set the timing.
One thing I did run into when wiring everything back up: There are two wires going to the coil, one is blue and the other is black with a white stripe. Which one is positive? The black one is thicker, and I'd have to say I've never seen a bright blue ground wire before, but you never know...
Tl;dr- Two wires go to the coil. One is black with a white stripe, and the other is blue. Which is positive?
Old Nov 27, 2010 | 09:48 AM
Black w/ white stripe is positive (12v+ switched). The blue is the tach signal (negative).
Old Nov 27, 2010 | 11:41 AM
Switchtr3's Avatar
Thanks nismo.
DeathByNissan55
May 28, 2014 07:32 AM
jgz
May 18, 2007 09:49 PM
CaptainZ
Sep 30, 2004 05:58 PM
83Z
Nov 20, 2002 08:22 PM
