Side door lights
Old May 2, 2006 | 02:12 PM
duowing's Avatar
NisTuner
Side door lights
Alright I'm trying to figure this out. I could have sworn that the little lights with the red covers in the bottom of the doors used to come on when the door was open. Well anyway now they don't. Does anyone happen to know where the fuse for these lights are located? My dome light and my little under dash lights come on when the driver's door is opened, but these lights don't. I've replaced the bulbs with no luck, so I'm thinking it's wiring or a fuse.
Old May 2, 2006 | 02:14 PM
Unscrew it from the door panel (or take off the door panel) and make sure the connection is still good. The one fuse should be for all the interior lights.
Old May 3, 2006 | 05:27 AM
naviathan's Avatar
It's the same fuse as the other lights, but those bulbs tend to blow often because of the door being slammed. Check the bulbs first. If that's not it then you will have to pull the panels and trace the wires back to find the bad connection.
Old May 3, 2006 | 04:29 PM
duowing's Avatar
NisTuner
Well the lights themselves work, I took them out and connected them to the wires under the dash. I noticed they all run on the same Blue-White, Blue-Red wiring. So I figure I'm gonna pull the door trim off and mess with the wiring.
DeathByNissan55
Dec 13, 2020 03:42 AM
brim
Sep 16, 2013 12:21 AM
ZCHondaCRX91
May 19, 2011 07:34 PM
B1nAryVilE
Jan 23, 2005 09:42 PM
kewlcat
Oct 26, 2001 09:36 AM
