right side door is ****'d
My right side door is not opening what so ever it doesn't open from inside or out and the lock doesn't work as well someone tried to break into my car and now the door is crap tacular i've tried everything to take off the door is there an other way of removing the whole door or just fixing it. any help would be great.
-chuck
-chuck
Pop all of the rivets on the inner door panel and lift it up and off the door. Under there is a plastic sheet that you can just peel off. Once you get that off you should be able to look inside the door and see whats wrong.
My $.02
-chuck
-chuck
if all else fails, take it to a good body shop. they should be able to help.
good luck, bj
ok this sounds stupied but spray WD-40 in the lock and try using the key to unlock the door i had to do it when my lock stuck. i dont know if that will work for you but try anyway :headspin:
OK well i got it to open i ordered the part turns out the whole mechanism where the hook clings on to the body is ****ed so right now i got it rigged with a aliminum wire solded to the hook attatched to the inside door handle just for now nothing temporary
-chuck
-chuck
DeathByNissan55
Dec 13, 2020 03:42 AM
