short shifter
Old Dec 16, 2004 | 10:30 PM
highwaystar's Avatar
short shifter
im gonna cut the shifter on my 280zx down about 2 inches for short shifting effect. is this a good idea or bad?
Old Dec 17, 2004 | 04:26 AM
DoTheDrew888's Avatar
How are you going to re-thread the shift ****?
Old Dec 17, 2004 | 10:46 AM
Dorifto's Avatar
I took 2 inches off off my shifter, and just put an AutoZone shiftknob and boot on it. I didn't even thread it - just drilled some divets on the shaft for the mounting screws. I'm not sure how to post pics, but if you'd like a couple snaps, shoot me an email ( dorifto_motorsports@Yahoo.com ) ... I can send ya some hi-res pics.
I must say, it's loads easier to bang through the gears with a simple ~snick~snick~ of the short throw versus stock.
Old Dec 17, 2004 | 01:06 PM
280Z4ME's Avatar
I did the same to my Z. it did make a huge difference in shifting. I also did the drill and screw deal for a mount.
Old Dec 17, 2004 | 06:00 PM
ok thanks ill do er! wouldnt mind the pics either! ill shoot u an email
Old Dec 17, 2004 | 09:08 PM
sk8ur_9's Avatar
hey Dorifto :how do i cut the shifter, with what tool ??
Old Dec 18, 2004 | 07:32 AM
Dorifto's Avatar
I used a cutting wheel and 5000 rpm drill. But if you want to get technical ...
Hacksaw.
Old Dec 23, 2004 | 11:30 PM
ZedZilla's Avatar
Lightbulb
Hey guys i'd use one of those high speed spin saws with a cutting wheel like Dorifto suggests. Should make things a lot easier then a good ol'hacksaw and if you still want the threads at the end after its all said and done, just drive it over to a plumbing shop and have them use their tap and die set to put the threads right back on i.e, after they match the threads on the section you just cut off and viola you can screw the old **** back on or whatever
Old Dec 28, 2004 | 06:05 PM
VenomousZX's Avatar
ok, pardon me if I got it wrong, but I thought a "Short-Throw" shifter was when the length from the mount/(bushings) to the linkage was increased to shorten travel distance when shifting thus resulting in a slight reduction, I don't see how hacking a couple of inches off of the stock shifter height you get the same effect :ranton:
Old Dec 28, 2004 | 09:27 PM
Heat Rave R's Avatar
By shortening the height of the shifter, the **** has less distance to travel between shifts. It's like shortening the radius of a spinning object; the edge has less distance to travel before reaching the same point again.
Old Dec 29, 2004 | 11:22 AM
Dorifto's Avatar
Aftermarket short throw shifters do relocate the shifter linkage for a closer gate spacing while retaining stock **** height and movement effort. By hacking off the stock shifter, you get the same effect, although the **** is the part that is relocated. While this allows closer spaced gates, the effort required to move it is increased. Cutting it off is simply a "ghetto" way of making your own short throw for the price of a cutting wheel or hacksaw blade ... cheap and efficient, I say .
Old Jan 24, 2005 | 06:52 PM
sk8ur_9's Avatar
yea it works(short shifter)
i cut my shifter about 3inch, it gives the same feelin like a real short shifter (works niice)*
Old Jan 26, 2005 | 09:59 AM
theramz's Avatar
I have a present for you...
I have the tooling to do this in a lathe and re-thread it. I've done 26 of them so far with no complaints. I also make new bushings. It makes a huge difference!
Old Jan 26, 2005 | 01:55 PM
lww's Avatar
lww
Head Muckraker
While you've got it off, definitely put in new bushings. This will make a tremendous difference in the feel and will prevent you from having to 'hunt' for the gears.
WanganDevilZ
Jan 6, 2010 09:59 PM
ern
Jun 22, 2006 08:51 AM
hogboy36
24
Nov 4, 2005 08:04 AM
Lucky91647
12
Mar 27, 2005 09:43 PM
nka04a
Mar 15, 2005 07:02 AM
