Sensors
Old Dec 19, 2012 | 12:44 PM
zordietrying's Avatar
Sensors
I went to autozone to replace both of the one wire sensors in the thermostat housing for my 82 280zxt. In the book they are called thermotime switch and water temperature sensor. They could only find one, which they called Temperature switch.(the one with a nipple on it) The other they called coolant sensor, which was the CHTS.(two wire) What is the other called and where can I find it? Thanx
Old Dec 19, 2012 | 01:08 PM
https://www.zdriver.com/forums/280zx...al-help-32114/
There are 3 sensors...
#1: Water temp sensor for dash gauge
#2: Water temp switch for the aux fan
#3: Thermotime switch for the cold start valve.
From the FSM (you should download it here: XenonS130 - S130 Reference if you haven't done so yet).
EDIT for clarification:
#3 Thermotime switch is not present on the L28ET as there is no cold start valve.
Old Dec 19, 2012 | 02:11 PM
I got a thermal transmitter. (called temperature switch at autozone) I still need a Water Temperature Switch. Which I can't find. Does the parts stores call it something else.
Old Dec 20, 2012 | 10:46 AM
lifegrddude's Avatar
Externally Wastegated
If you ask Courtesy Nissan at courtesyparts.com, they'll give you the correct part number for that item. I can't remember the exact name of the parts the local auto store uses, but try having them check under the a/c section of their system. That's how the guy at my local O'Reillys found it.
Old Dec 20, 2012 | 11:17 AM
icice9's Avatar
Super Siver & Black Stud
here you go
Import Direct Ignition 17-1060 - Thermo Fan Switch | O'Reilly Auto Parts
Old Dec 20, 2012 | 08:46 PM
That's the one, thanks guys. One more quick question, should Teflon tape be used on those two sensors?
Old Dec 21, 2012 | 01:30 PM
Nope - you want as good of an electrical contact as possible between the sensor and the socket. If you absolutely need something in there you could use a thin smear of conductive grease (NOT dielectric - that means it DOESN'T conduct electricty).
drummer69
May 30, 2006 07:33 PM
81 Black L28E
Oct 6, 2005 06:54 PM
Brewster
May 1, 2005 10:05 PM
tt300z
Jan 16, 2005 09:43 PM
tenjin
Apr 19, 2003 09:43 AM
