Run the digital clock off a battery
Old Feb 24, 2011 | 07:05 PM
mrprofile's Avatar
So I got a tri gauge with a digital clock at a junkyard and wanted to put it in my car but I have an analog clock, so its missing some of the wires to get it to work with a digital clock.
I wanted to do some experiments to see if the clock actually worked, and to see if I could just run my own wiring in the car to power the clock. so I spent the last three hours or so trying to figure out which wire did what on the digital clock by looking at the tri gauge breadboard. For example if a line on the breadboard went to the voltmeter and also to a digital clock wire then I would figure that if the voltmeter is always on then this must keep the clock always on as well or, if a line goes to the ground for the running light bulbs then this must be the ground for the lights on the clock. anyway I connected two 6 volt batteries together, making them 12 volts, hooked up all the wires where I thought they should go and here is the result:
I just hope im not burning it up, has anybody seen the clocks glow? is it that bright?
Old Feb 24, 2011 | 08:11 PM
Yeah that looks fine. It is that bright when you have the face cover off. Funny thing, I want to convert to an analog clock. So I can do my purple lighting theme in my interior. lol I actually have an analog clock cluster. Just don't know if the clock works or not. It would be pretty cool if it did. I will find out sometime here soon.
Old Feb 24, 2011 | 08:51 PM
mrprofile's Avatar
hey yours in gonna be a lot easier because its already wired, just hook the blue wire up to spot where the + symbol on the breadboard is, and hook the black next to the - symbol, there should be leads, those lines are always on.
and hey if you ever get a chance to turn on ur digital clock with the cover off could you feel the blue resistor with 3 brown bands and a gold band, mine gets really hot almost instantly and im wonding if that should happen, its easy to get to, you can actually see it in my picture. and u can get to it even with the metal mounts.
jasongeek
Feb 1, 2012 04:32 PM
mrprofile
Feb 23, 2011 09:41 PM
GKLB1
Jul 27, 2010 10:03 PM
vorhese234
Feb 12, 2006 06:48 PM
Cw2435
Aug 5, 2003 09:05 PM
