Resurrection of a Golden Z
Old Aug 10, 2011 | 06:33 PM
GOLDNZX's Avatar
I just got myself a new Z. I'm looking for any type of help or info anybody can give me.
It's a 1983 Datsun 280ZX. Non-Turbo. This car had been sitting for about 5 years before I got it. The interior is real clean, but the exterior and engine need work. The odometer reads 400,xxx miles. The car starts, but ends up turning off after a few seconds.
I've already replaced spark plugs, spark plug wires, fuel filter, fuel filter hoses, oil, oil filter, and battery.
A few questions I have:
What else should I replace?
Where can my problem lie?
What do you suggest I do?
I've always loved and respected the car but I don't even know where to start.
Here are a few pics of the car.
Old Aug 11, 2011 | 07:46 AM
Welcome to ZDriver!
First, 400k miles is awesome!
Second, when the motor dies, does it start right back up?
Have you checked the fuel pressure?
Have you checked the timing?
Have you checked all sensors & connections?
Old Aug 11, 2011 | 03:51 PM
GOLDNZX's Avatar
Thanx. I'm surprised to hear 400k miles is awesome but I'm glad. When the motor dies, I turn the key all the way off and start it right back up then it starts but continues to do the same thing.
I will check all that today if I get the time to.
Old Aug 11, 2011 | 04:43 PM
sonethirty's Avatar
Alternator?
Old Aug 12, 2011 | 03:48 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Ignition switch?
Old Aug 15, 2011 | 04:41 AM
Check your AFM (air flow meter) It could be faulty. Also as Nismopick suggested. Check all your sensors, and also any parts to do with the ignition. Trouble shoot, and check the contacts. The tests will be in your car manuals. (Haynes or FSM) Also you could have a fuel problem.
But I am willing to bet it is electrical and something to do with the ignition system. There are quite a few things that could be causing the problem. So it is a matter of narrowing it down, and finding the culprit. Good luck, and keep us posted.
Old Aug 19, 2011 | 02:09 PM
GOLDNZX's Avatar
Ok I finally got the chance to troubleshoot. Below I'm attaching a video of the engine while it was on.
I checked the fuel pressure while it was idling and it was well over 30 psi. While at full throttle it was over 37 psi. Fuel pump cut-off discharge pressure was over 64 psi.
I also checked the fuel injector coil resistance. All of them were either 2.6, 2.7, or 2.8 ohms.
Old Aug 25, 2011 | 07:35 PM
GOLDNZX's Avatar
Its been a while since I last updated you guys.
I completely forgot to mention that the friend I got the car from had bought a new battery and accidentally connected the positive/negative wires the opposite way.
Keeping this in mind I came to the conclusion that the ECU is fried. It seems as if the engine is not reading how much air is entering and I noticed that the check engine light doesn't even turn on. When obviously it should be ON.
I ordered the part, so it should be here soon. I'll see what happens when I receive and change the part.
Old Aug 31, 2011 | 10:39 PM
flightforlife07's Avatar
been there done that check your fusible links too they usually burn out before the ecu
Old Sep 2, 2011 | 06:36 PM
GOLDNZX's Avatar
Thanks i already did change the fusible link but I've had no type of luck looking for an ECU. Do you know anywhere I can get one?
Old Sep 2, 2011 | 09:27 PM
im not sure if they are different but i have one from a 1980 n/a 280zx... with n47 head... if u find out pm me
Old Sep 5, 2011 | 06:39 PM
http://cgi.ebay.com/ebaymotors/CARDO...item27ba86ef30
Here is one on ebay, though a little pricey. I would suggest posting a wanted add for one.
http://cgi.ebay.com/ebaymotors/NISSA...item4aa12d98fb
And another one much cheaper from a salvage yard.
Hope that helps you out. Good luck.
Old Sep 23, 2011 | 04:31 PM
GOLDNZX's Avatar
It's been quite a while since I last updated but the Z is now alive. Its starting and moving now.
It's lacking some power because 2 of the fuel injectors aren't responding. I'm going to try to take it out on the highway and see if the fuel injectors are just clogged from not being used in 5 years.
I took a little video of it being started:
I'm thinking about just buying it some new fuel injectors so that it could feel nice and fresh.
Old Sep 24, 2011 | 12:08 PM
.... that would be the easiest 4 cylinder to 6 cylinder swap I can think of
Old Nov 21, 2011 | 06:58 PM
GOLDNZX's Avatar
It's been a hell of a long time since I last updated.
The ZX is slowly progressing. I changed all 6 fuel injectors with some injectors from Germany. They have a squared tip instead of the regular round one. While i was at it I changed the fuel pressure reg. The engine is no longer shaking and sounds much better. I also changed the AFM. I have a radiator that was bored out and painted sitting around. I should be putting that on the car soon.
I'm having a few problems though. I need some help trouble shooting.
---> When I start it while cold, let it idle for a couple seconds, then press the gas, it starts to bog. But when it is nice and warm the bogging is gone. What could it be?
Old Nov 23, 2011 | 02:40 PM
Lesnocker's Avatar
A datsun 2.8....... All three of mine have that exact same bog. Then when you mash it cold they smoke for a sec. They never stall though.
Old Nov 23, 2011 | 08:57 PM
GOLDNZX's Avatar
Yeah mine never stalls either.
Old Nov 25, 2011 | 07:00 PM
Check the EFI manuals, FSM, etc.... but if it runs bad when its cold and fine when its warm.... dunno maybe the cold start injector?
Old Dec 18, 2011 | 11:36 PM
GOLDNZX's Avatar
Update: Today my Datsun suddenly started to lose power. I was flooring down the gas pedal but it took a very long time to speed up. At one point when I was driving home it didn't accelerate at all. I was going about 5 mph's. The engine was real shakey. Especially from the right side of the engine where the manifold and exhaust are.
What could the problem be? I need to fix this soon.
Old Dec 19, 2011 | 05:03 PM
GOLDNZX's Avatar
Today I cleaned out the fuel filter and I found that there was a lot of deposits. Looked like rust though. Since the car was sitting for a couple of years I am wondering if I should just go ahead and change the whole gas tank?
I need some help getting my car running smooth since I use it to go to work and school.
This is random but.... What type of header/exhaust set up should I throw on it? I feel like I need to swap that out too.
Old Dec 19, 2011 | 07:41 PM
ThaPimpShrimp's Avatar
Mine does the same thing at about 1,500 - 2,000rpms. I have discovered that I think it is just the warm up phase of the engine. I am running a z31 ecu but it seems like as soon as the CHTS is reading a high enough temperature this bog goes away.
Old Dec 21, 2011 | 08:12 PM
GOLDNZX's Avatar
My car doesn't want to turn on again like it did when i first got it.
I'm pretty sure my fuel system is real dirty. Any pointers on how or what to use to clean out the whole fuel system? (i.e. gas tank, fuel pump, fuel filter, fuel lines, fuel hoses, etc.)
I need to find a gas tank for a cheap price because I am pretty sure it needs to be replaced. If there is another way i can go please let me know so I wont have to waste money.
TeamRonin
Apr 13, 2010 05:37 PM
Bleach
Mar 30, 2009 02:36 PM
Mike240Z
Nov 8, 2002 09:00 AM
