240 Resurrection
Old Nov 7, 2002 | 09:44 AM
craigdb's Avatar
Re: 240 Resurrection
18 years? Great find!
I would think all the rubber would be suspect, not just the hoses, but tires and bushings as well.
In addition to fluids (it might not be a bad idea to drop the gas tank and get it cleaned out before new gas is added) you might want to replace all filters and gas lines whether its needed or not.
A new battery wouldn't hurt either. Then check and clean or replace the distributor cap (the plastic degrades and they crack), points, plugs, spark plug wires, etc.
Flush the radiator real good too. There will more than likely be a ton of crap in it.
Old Nov 7, 2002 | 10:00 AM
remove the spark plugs and put some WD-40 or engine oil in each cylinder. A couple spoonfuls I guess.
Put a big socket on the front of the crankshaft and slowly turn the engine around a few times to get some liquid on the rings
GOLDNZX
Dec 21, 2011 08:12 PM
TeamRonin
Apr 13, 2010 05:37 PM
