Problems removing BMC
Old Jan 29, 2011 | 02:56 PM
AKZX's Avatar
This may be kind of a noob question, but I'm trying to remove my BMC, and I can not for the life of me get thee brake lines off of the underside of the cylinder. Should I be trying to get the check valves off too?
It's a 1980 ZX NA and FSM has been of no help so far.
Old Jan 29, 2011 | 04:04 PM
Welcome to Zdriver man. As for the brake lines. You need a brake line wrench. It will be 10mm I think. I just bought one a short while back. Do not use a regular wrench on the lines. You will round off the nuts. Then you just have the 2 12mm nuts, and the master cylinder should come off. Along with the plate, that holds your heat shield on. Hope that helps, and good luck.
Old Jan 30, 2011 | 01:10 AM
AKZX's Avatar
Thanks, I'll pick one up tomorrow. Heat shield and 12mm weren't a problem, but just like you said, these ones just round right off.
Old Jan 30, 2011 | 11:47 AM
rogerz's Avatar
Grumpy & Helpful
if you can't get it off with a tubing wrench use vise grips.
Old Jan 30, 2011 | 03:33 PM
260zturbo's Avatar
Stupid Hurricanes...
http://www.sears.com/shc/s/p_10153_1...=1296430268629
i wouldnt use a vise grip unless you plan on redoing the fitting.
Old Jan 31, 2011 | 08:59 PM
AKZX's Avatar
Yeah, vice grips are a no-go. Nowhere in town has a tube wrench. Sears, Lowes, all local hardware store are sold out and NAPA and O'Reilly only have sizes down to 11mm in stock. Looks like I'll be ordering online..
Old Jan 31, 2011 | 11:05 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
Originally Posted by AKZX
All local hardware store are sold out.
****, everyone is buying up all the brake line wrenches?
Order me a few, I need like 6, just in case.
Crusty_Lips
Aug 21, 2013 10:32 PM
Turbo Biscuit
Mar 29, 2012 07:37 AM
plainwhiteZ
Dec 22, 2007 04:14 PM
skittle
Nov 17, 2006 06:12 PM
n666
350Z Apperance Exterior, Interior
Dec 17, 2005 01:55 PM
