Power locks and windows
Old Apr 10, 2009 | 10:10 AM
280zdude's Avatar
Just curious but does any one know WTH they put power windows but not power locks on an 82 zx.
On that same note, has anyone here moved their window switched fromt the door to the console. I keep hitting mine with my knee and it will sort scare the crap out of you when you are making high speed manuvers and the window start going down. Anyway, i was just wondering how much trouble it is to move them from the door to the console.
Old Apr 10, 2009 | 10:13 AM
82-83 ZX's have power door locks... the driver's door locks & unlocks the passenger side.
Do you not have the plastic frame cover for the window switches? It wouldn't be hard to move them, just gotta rewire it...
Old Apr 10, 2009 | 10:15 AM
280zdude's Avatar
explain the power door locks. I am used to domestic autos that have the actual button. this has no button.
Old Apr 10, 2009 | 10:21 AM
Lock / unlock the drivers side... the passenger side locks / unlocks. I don't think the passenger side will do the drivers side though.
Old Apr 10, 2009 | 10:22 AM
280zdude's Avatar
what about when you enter the car, if you unlock the drivers door with a key should it unlock the passenger door at the same time?
Old Apr 10, 2009 | 10:24 AM
Yep. The drivers door lock system has an actuator that sends the same signal to the passenger side.
Old Apr 10, 2009 | 10:25 AM
280zdude's Avatar
what if it ain't working, where should i start looking?
Old Apr 10, 2009 | 10:30 AM
In your Haynes manual.
Then on to fuses, relays, wiring, actuators....
Old Apr 10, 2009 | 10:32 AM
280zdude's Avatar
Cool. I can't wait to get that working. I hate making someone stand outside while I try to get settled in my fetal position for driving.
Old Apr 10, 2009 | 09:03 PM
JhnRX7's Avatar
On mine, the passenger side locks with the driver side... however, it will not unlock with the driver side. I just assumed thats how it was supposed to be.
I need to figure this out and get it fixed!
Old Apr 17, 2009 | 05:51 AM
280zdude's Avatar
OK. I found a section in the manual I downloaded about the power locks, but it doesn't tell me where the flippin fuse is located. I looked all thru the owners manual, and on the front side of the fuse cover...nothing about power locks. I am going to try to fix this this weekend, but I sure hate starting off blind. Any help will be greatly appreciated.
Old Apr 17, 2009 | 07:53 AM
your passenger side actuator probably is broken. I had that happen. Open up the door panel from the inside and look.
From the factory, the pass door is the only door with a mechanism. My 280ZX has power locks both sides but the actuator in the driver's door is aftermarket and hooked up to an aftermarket alarm. (keyless entry!)
Old Apr 18, 2009 | 09:13 AM
280zdude's Avatar
Well bleach you were almost right. It was acually missing....ARGH!!!! On to the scrap yard......one day.
Old Apr 18, 2009 | 01:23 PM
nismo619's Avatar
on my 1983 n/a/ the passengers side locked both sides as well as the drivers side. my 1982 has key problems im savin up enough money to buy new keys.
Old Apr 18, 2009 | 05:39 PM
KingDatsun1's Avatar
I put keyless entry on my car and regret it,
sometimes it works, sometimes it doesn't.
much easier unlocking the car manually imo.
FubarI33t
Jan 7, 2008 10:28 AM
passaphist
Jul 1, 2007 09:14 AM
n_2_fairladyz
Feb 7, 2006 02:58 PM
DarrellBuddy321
Dec 29, 2004 07:21 PM
Heat Rave R
Oct 11, 2004 09:18 PM
