plug underneth the intake manifold
Old Aug 29, 2009 | 07:11 PM
captken's Avatar
ball bearing or something inside it that moves up and down. Located next to turbo sleeve, you know, has 2 hose clamps hooked together.
I pluged it, does this have any thing to do with wastegate atuater or turbo funtion?
kenny and jimmy
Old Aug 29, 2009 | 07:38 PM
BlueKitsune's Avatar
Intrawebz Wizard
*facepalm*
by the sounds of it Its the PCV (Positive Crankcase Ventilation) Valve. It should be hook into that pipe the come out from the block on the drivers side under the dizzy. And you need it hooked up else you want something to blow up.
Old Aug 29, 2009 | 08:44 PM
flatblack's Avatar
Smile
*facepalm*
by the sounds of it Its the PCV (Positive Crankcase Ventilation) Valve. It should be hook into that pipe the come out from the block on the drivers side under the dizzy. And you need it hooked up else you want oil bwlo-by
Corrected.
How would not having the PCV hooked up blow something up?
Hmmmmmmmmmm??
Old Aug 29, 2009 | 08:57 PM
captken's Avatar
install filter
you are talkin avout the pipe off the engine block?
can you not intalll a filter?
Where does it gon anyhow and what does itdo?
thankx,
kenny and jim.
Old Aug 29, 2009 | 09:02 PM
Intrawebz Wizard
Originally Posted by flatblack
Corrected.
Hmmmmmmmmmm??
Hey I was trying to scare him! lol
Anyways Yes Im talking about the pipe off the engine block... what other pipe is there? and you can but its a very bad idea. Where does it go? Uh lets see it goes from the pipe to the PCV valve with a rubber hose.
Your welcome lol
Old Aug 29, 2009 | 09:05 PM
flatblack's Avatar
thankx,
kenny and jim.
Lol you are in serious need of a Haynes manual or FSM
Yes it's the pipe off the engine block under the manifolds near the front cover.
Some people block it off and put a filter on the valve cover opening. Sometimes this can lead to oil coming out of that filter but usually it's not that big of a deal, although frowned upon.
Old Aug 30, 2009 | 06:19 AM
captken's Avatar
thanx
Thanks for clearing that up for me....
this engine was tore down in 06...I can't remember where everything goes.
I do have a fsm for the car, just can't make heads or tails on the drawings, I honestly could not find that valve. I blew thru it, mine opened both ways, thought I'd loose turbo boost. In this case, id go back into the engine...?? maybe the valve is bad, anyway I blocked it off and will put a filter on the pipe coming outta the block.
I should have her running today and will report back progresss
thankx to all at zcar, without you guys Id be fed.
kenny
Old Aug 30, 2009 | 12:05 PM
flatblack's Avatar
I should have made that more clear - the filter goes on the valve cover breather [you know where the valve cover is, right?] and block off the pipe coming off the block as well as the hole under the intake mani.
Old Aug 30, 2009 | 02:44 PM
njgheewala's Avatar
Dunkin' Donutz
kenny
YOU mean zdriver!?
Old Aug 30, 2009 | 03:52 PM
^^^ I think "Jim Bean" musta been talking.
Old Aug 30, 2009 | 06:26 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
wait whats this "PCV"....
Old Aug 30, 2009 | 08:47 PM
It's a black hole that leads to a parallel universe.
If you were being serious, GOOGLE "PCV".
Old Aug 30, 2009 | 11:24 PM
captken's Avatar
zdriver
Originally Posted by njgheewala
YOU mean zdriver!?
sorry bout that, zdriver guys are more friendly than on the other forums, thats why I hardly ever post there.
I do apreciate everyones help, when you have a quesstion and post it here it gets answered.
I met Fubar here, and everything he worked on for me was spot on..and we became friends.
Hope he stays safe in Iraq.
kenny, jim left the building for good.
Old Aug 31, 2009 | 12:12 AM
be carefull that valve adjusts your perception to the 4'th dimension!
Old Aug 31, 2009 | 05:13 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Nice!
noelawinslow
May 21, 2013 01:17 AM
Fairly Z
Sep 12, 2011 07:25 PM
Niku-Sama
Jan 17, 2008 05:03 PM
veyenyl
Mar 10, 2007 09:47 AM
Captain caveman
Aug 11, 2005 10:14 PM
