Ok, So This
Old Oct 4, 2006 | 07:43 PM
FubarI33t's Avatar
Ok, So This
I tryed to start my 81 today. She would not start at first. I had to open her to WOT to get it to spudder. Then i kept trying and it started up. But even at WOT it would not go over 1500RPM. and if i let go of the gas, it died instantly.
I have to hold the starter down to help it build up enough momentum to get going. Yes there's gas in the car.
Old Oct 4, 2006 | 07:48 PM
but is there gas FLOWING????? check the pump ehh? sounds like it wants fuel BAD.
Old Oct 4, 2006 | 07:50 PM
FubarI33t's Avatar
i got psi at rail.
Old Oct 4, 2006 | 08:08 PM
well...this isnt my suggestion....someone elses....vacumme related perhaps?
Old Oct 4, 2006 | 08:12 PM
Z Car Barbie's Avatar
User Friendly
Have you read this thread, Fubie? https://www.zdriver.com/forums/showt...osition+sensor
Old Oct 4, 2006 | 08:34 PM
hey fub is the timing correct, if the dizzy is a few teeth off it will have those symptoms, mine did that after i re-built the engine, i was only one tooth off on the oil pump drive, check for tdc, and then for proper placement of the rotor position in corrospondance to the cap #1 position
Old Oct 4, 2006 | 09:00 PM
FubarI33t's Avatar
well. it ran fine when i parked it, the timign is off, cause i have not been able to set it yet. i had to turn the dizzy just to get it up to 1500K RPM
Old Oct 5, 2006 | 08:39 AM
FubarI33t's Avatar
I disconnected the tps and started it up. it changed nothing. it won't go over 1200K and it is rough at that. it's like the engine only has two speeds, 1200K and stop.
Old Oct 5, 2006 | 08:46 AM
Check your AFM & CHTS connections. Your AFM may need adjusting...
So it ran fine one day, and crappy the next?
Old Oct 5, 2006 | 08:53 AM
FubarI33t's Avatar
yeh. it was burning oil. but she was runin great. it ran out of gas, i decided on playing with it, so yesterday i put gas in it. and this started
Old Oct 5, 2006 | 08:56 AM
What kind of gas??!?!?!
Old Oct 5, 2006 | 08:58 AM
FubarI33t's Avatar
87Oct. i would of put 93 in it. but it's 15 miles to the nearest 89-93Oct seller.
Old Oct 5, 2006 | 09:07 AM
Check the sensors. Also check the sparkplugs to see if they all look the same.
Old Oct 5, 2006 | 10:23 AM
FubarI33t's Avatar
I checked plugs. 2,3,4,5 are flooded. 1&6 show normal. I started the car and ran it WOT to get 1200K for a few min's to see if it could work it's self out. Every 10 secounds or so you can hear one of the flooded cyclinder's kick uin and it rev up a lil, But would drop right back down to 1200K. By the way it sounds, and how rough it is at 1200K, i'd say it's only goin off of 2 cyclinder's
Old Oct 5, 2006 | 11:12 AM
naviathan's Avatar
Check the fuel pressure with a pressure gauge. At idle it should be around 28-32psi.
Old Oct 5, 2006 | 12:36 PM
FubarI33t's Avatar
i got pressure. i got a gauged mounted ontop of my rail. she's right where it's supposed to be
Old Oct 5, 2006 | 01:15 PM
naviathan's Avatar
Ok, check your CHTS (cylinder head temperature sensor). If it's not connected or gone bad then it will make the car run really rich.
Also check your ignition box on the dizzy. It could be kicking the bucket.
Old Oct 5, 2006 | 04:45 PM
User Friendly
It sounds like you may have a vacuum problem, Fubie. A clogged PCV Valve might explain the "burning oil". Test it and let us know the results. Also, test the EGR Valve, so we can rule those out.
Old Oct 5, 2006 | 05:04 PM
FubarI33t's Avatar
EGR has been blocked off. and PCV=What and where?
Old Oct 5, 2006 | 07:30 PM
z-hag's Avatar
Queen of Yachts
positive crankcase ventilation. location, anyone-----
Old Oct 5, 2006 | 07:42 PM
FubarI33t's Avatar
i poped a Oil Breather filter on my valve cover. i am geting smoke out of it, and if i pop the oil cap. lots of smoke in there too.
Old Oct 5, 2006 | 07:55 PM
thxone's Avatar
Is there any oil LEFT in the engine??? What are those cylinders flooded with? Gas...Oil???
Old Oct 5, 2006 | 08:04 PM
User Friendly
I would assume oil - that's why I think he should test the PCV Valve. It's located in the center, upper engine area, mounted in the intake manifold. Maybe someone can post a picture to show you what it looks like, Fubie.
Old Oct 5, 2006 | 08:15 PM
thxone's Avatar
Well with the PCV valve it would have to be busted pretty good to let the oil enter it and I would assume through the vacuum of the engine be sucked into the combustion chamber....not sure per say but isn't this the PCV? I have only ever seen them attached to a valve cover. (red arrow)
Attachment 5301
Old Oct 5, 2006 | 08:45 PM
User Friendly
Yup, that's it. Good job, Thxone! I forgot that some were mounted to the valve cover. It's mounted in the intake manifold on my 82 NA.
