oil pressure, help
oil pressure, help
i have a 280zx that i bought brand new and have taken very good care of, but all of a sudden my oil pressure at high rpms will drop to 0, the light wont come on but then if i press the clutch in the pressure will come back but will drop agine, sometime if i go a lower speed it will come back, is better when cold, also can i remove the oil pmp without removing the frnt stbilizer bar?? and lastcan i pull the regulator valve while the pump is still in the car??
your oil pressure is probably ok. those pumps don't wear out in anyone's lifetime. sender and gages (stock) notoriously unreliable. if really worried install an after market unit. you didn't state your mileage but unless it is north of 500K I really wouldn't be concerned. like fric frac said check the connection. maybe replace the sender.
