Noise from the dash
Old Jan 27, 2005 | 08:54 PM
CWHammer's Avatar
Under My Car... brb
Noise from the dash
My 83 has something squea ling from behind the dash. I have the auto climate control and I turned the fan off but the sound was still there. The only way to make it stop is to turn the key off. Brings me to two questions;
1. With the auto control does the fan still run even if the system is off?
2. What else would there be in there to make a squealing noise?
Old Jan 27, 2005 | 09:28 PM
Dorifto's Avatar
If I remember correctly, there's a little fan - much like a computer fan - that keeps the controls cool, I believe. That fan could be wearing out, or perhaps has spun a bearing. Maybe unplugging it or replacing it could help.
Hope this helps,
-Dave-O
Old Jan 27, 2005 | 10:40 PM
CWHammer's Avatar
Under My Car... brb
Awesome! :hpydance: Any idea on the general location of the fan? I bet I could find a replacement at RadioShack.
Old Jan 28, 2005 | 11:29 AM
to the right of the center of your dash you should see a little round vent. (half inch diameter) straight below that is a little spinning fan that sucks in air to see how hot or cold it is inside. That fan is probably what is making the noise. They go out as well as the thermostat they are attached to. (this is why the auto climate sucks)
You can get to it if you remove the glovebox.
Old Jan 28, 2005 | 01:57 PM
Carl's Z's Avatar
Is there a chance that this may be the speedo cable squeeling????
Old Jan 28, 2005 | 10:31 PM
s/cL3.0's Avatar
Bleach is my Hero
I took my plate with the ac unit in it out, to get to that fan.. It is very annoying.
Old Feb 2, 2005 | 08:25 PM
CWHammer's Avatar
Under My Car... brb
What would be a better option - replacing the fan and thermoresistors to get the system to function properly, OR changing to a more controllable manual setup?
bataradena
Jul 25, 2010 07:35 AM
turbojohnny
30
Jun 18, 2009 10:36 PM
CWHammer
Jun 22, 2008 08:01 PM
marcello129
May 12, 2005 04:17 AM
duckyz
12
Mar 7, 2005 04:51 PM
