new here need help 280 has no spark
Old Feb 23, 2011 | 05:47 PM
speed_z's Avatar
hey everybody new here helping my bud with his 280zx turbo that doesnt spark there is no spark at the coil hes changed the ignition coil and checked the injector computer and everything seems fine also check the power at coil and its at 4 volts with a multi meter the i kept power prong at power coil ring and changed the ground prong to another ground like at suspension post and then it read normal voltage so i guess its not sparking cuz of bad ground but weve checked everything and it all seems to be hooked up right could there be anything else causing this and what would happen if i ran a better ground staright to the ignition coil thanks in advance
i have also heard of some kind of igniter is that the little plug thing located on the left side seperate from the coil ?? if so as i was cranking it if u move the plug on that thing it would spark but only if that plug was being moved
Old Feb 23, 2011 | 09:14 PM
Welcome to Zdriver. Are you talking about the resistor, a little away from the coil? If so, maybe it still isn't grounded properly. Or maybe the resistor is bad. I don't know how different it is on a turbo. But maybe it will help. Good luck.
Old Feb 23, 2011 | 10:36 PM
speed_z's Avatar
i got this pic from the forum but its that plug to the left of the plug
Old Feb 23, 2011 | 10:47 PM
that little 2prong doodad attached to the coil bracket is the ignitor
Old Feb 23, 2011 | 10:48 PM
speed_z's Avatar
yeah that little plug thing if u move that thing in and out while cranking is the only way it will spark
Old Feb 24, 2011 | 12:44 PM
zordietrying's Avatar
Replace it or better yet put in a GM one there cheaper and last longer.
Old Feb 24, 2011 | 03:17 PM
Sorry for the misinformation. I don't even have that plug on my N/A. I still have things to learn about turbo Z's.
Old Feb 24, 2011 | 03:22 PM
If moving it makes it spark, I wonder if maybe it is just a bad connection. check the wires condition and the contacts for being clean
Old Feb 24, 2011 | 06:13 PM
speed_z's Avatar
is there a way that the distributor communicated with the coil and tells it when to spark maybe?
Old Feb 24, 2011 | 06:27 PM
country's Avatar
I had the same problem no spark on my 280z. I had a ground wire wrong on the transistor next to the fuse box. I looked at a tech manual to see how it should go but i am not sure if a zx is the same.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
Boosted Z
Dec 4, 2005 06:53 PM
Beseke
Jul 26, 2005 11:16 AM
z4doug
May 21, 2005 05:43 PM
