New Gauge
Old Jan 22, 2008 | 03:42 PM
BackHouseZ's Avatar
Cool New Gauge
Hey i pulled this 130mph gage out of a 79 zx in the bone yard. I have a 1980 280zx as you can see and i was wondering is there an easy way to install.. Does the needle come off or do i have to put the odometer in if so is there a way to reset it.
Old Jan 22, 2008 | 03:45 PM
You get to remove the gauge cluster, tear into it, remove the old speedo unit, and install the 130 unit. Lots of fun. There's not really any way to recalibrate it on your own. It's set for 3.7 gears.
Old Jan 22, 2008 | 04:12 PM
Niku-Sama's Avatar
eff good grammar
thats because 3.7 gears ROCK!
whats that jim-jam next to the guage?
Old Jan 22, 2008 | 04:15 PM
BackHouseZ's Avatar
Jim thingy
ahh its like a heater control valve i think, my heater does not work it was leaking and i dont think it ever worked since i've had it but someone told me it could be my core was bad or that think you see there. Antifreeze in my passenger side floor
Old Jan 23, 2008 | 12:17 AM
lww's Avatar
lww
Head Muckraker
All 280ZX speedo's are set to the same ratio. It's the speedo cog in the transmission that is calibrated to the differential gearing depending on how many teeth the cog has.
You're local mechanic should know if there's someone in your area that can calibrate your speedo and reset the odometer to your correct mileage.
It's a pretty easy conversion that is done all the time on these cars. Here's a pic of my 210mph speedo:
Old Jan 23, 2008 | 04:06 AM
Sweets's Avatar
Usedta be Justin260z
I want you to find me another speedo like yours, lww. I WANT
Old Jan 23, 2008 | 06:30 AM
Ah yeah! Tranny cog.... I forgot all about that. Doh!
Old Jan 23, 2008 | 10:49 AM
Sweets's Avatar
The cogs are color coded. I forget which one is for what though.
Old Jan 23, 2008 | 01:07 PM
Niku-Sama's Avatar
eff good grammar
is changing the cog a take the tranmission apart affair or can you get to it from the outside
Old Jan 23, 2008 | 01:11 PM
Outside. It's where the speedo cable hooks on to the tranny. 10mm bolt & you can pull out the cog.
Old Jan 23, 2008 | 01:42 PM
210 mph lol. you cheater n00b. thats SUPPOSED to say KMH
Old Jan 23, 2008 | 05:28 PM
Here's the link about speedo cogs:
http://www.geocities.com/zgarage2001/engine.html
YELLOW is the 16 tooth for the 3.36
BLACK is the 17 tooth for the 3.54
BLUE is the 18 tooth for the 3.70
WHITE is the 19 tooth for the 3.90
RED is the 20 tooth for the 4.11
PURPLE is the 21 tooth for the 4.38
Old Jan 23, 2008 | 10:45 PM
Niku-Sama's Avatar
eff good grammar
ahh that link may have given me more info to check my cold idle problem
Fast240Z
May 2, 2005 01:08 PM
danielschoenwald
Sep 5, 2003 03:26 PM
Ramen Sama
Apr 28, 2003 06:26 PM
danielschoenwald
Oct 11, 2002 06:16 PM
