Need some advice..
Old Jul 15, 2006 | 04:56 PM
n00blar's Avatar
Question Need some advice..
I'm ready to send my spare 1982 ZX's engine block to the machine shop.
Basically what I'd like to gain, after the entire block has been upgraded, is some boost in performance...nothing fancy, but a bit more of performance would be nice.
So, I've been reading, and a friend's been telling me, about cnc machine shops for the engine's head. Will this be too much or is there some other way for me to get boost in performance that I'd like.
Oh, yeah and I'd like to keep this project around $2,000
I also noticed that MotorSport Auto sells some head kits, but don't know if they're what I'm looking for.
Thanks for any suggestions you guys might have.
Old Jul 15, 2006 | 05:04 PM
For $2k you can do a lot!!!
-Bore the block & get oversized pistons
-Shave the head
-3 or 5 angle valve grind
-Mild cam
-MagnaFlux & Cross peen the rods
-other minor details....
Total for engine... about $1000
Then get an aftermarket igniton & coil... $200
Exhaust... $300
Old Jul 15, 2006 | 05:12 PM
n00blar's Avatar
-Shave the head
Nismo, give me more details if you don't mind
I'm completely new to this project and I'm doing as much research and learning as I can. I will bore the block, but what kind of oversized pistons do you suggest? I don't want to go 'fast and the furious' kind of profile, just a tad more performance would be nice...so I can get those 120+ MPH speedometers.
What about this cnc machining for the head, that my friend keeps telling me about?
Old Jul 15, 2006 | 05:20 PM
I would just contact a local GOOD (aka well known for their good work) machine shop.
CNC Machining isn't a machine shop... it's a way to cut metal. CNC stands for "Computerized Numerical Control" where you plug in axis numbers & the computer controls a cutting system to make a specific shape & size of an object... it doesn't apply too much in your case, tho the machine shop will set up the equipment to cut & shave parts acurately.
Old Jul 15, 2006 | 06:56 PM
Hey I have buried my 120mph speedo, in my '82 quite easily. It didn't take too long, and it was running over 5k rpms. My motor is pretty much stock form. I think the only upgrade is the accel coil, I have, which isn't much. Anyway good luck on building your motor. Your goal is not too far out of reach.
Old Jul 16, 2006 | 08:50 AM
the most important thing aboot building a good motor, is balance, it is the hardest upgrade to make later, and makes alot of difference, it also raises your redline!! very important. the other very important performance goody, is to get the head flowbenched, it increases the engines ablity to breath, start with those 2 things and i guarantee some great results, everthing else is bolt on, these cant be done later or for as cheap. i love to build high performance n/a motor, and have learned alot. trust me!!
Old Jul 16, 2006 | 07:26 PM
n00blar's Avatar
MSA sells a performance camshaft kit for about $580.00
I know these guys are usually not the cheapest, but is this the range of money for these?
Old Jul 16, 2006 | 09:30 PM
check out http://www.compcams.com/
I talked w/ one of their reps about a year ago, and they wanted about $200 for a custom grind.... I imagine it'd be even cheaper for a normal grind.
Old Jul 16, 2006 | 09:53 PM
lww's Avatar
lww
Head Muckraker
Exhaust... $300
Then, spend your last $500 on MegaSquirt and an MAF sensor.
You'll be able to tune the hell out of it with a MegaSquirt v3 PCB and the right sensors.
Good luck!
Old Jul 17, 2006 | 10:55 AM
n00blar's Avatar
Thanks for the link Nismo...they have a 'step up' camshaft for aroun $160.00. They don't seem to carry a 'kit' like MSA does.
Old Jul 17, 2006 | 07:04 PM
make sure you buy new rockers, itll "tick" forever if you dont, and wear your new cam funny, i found a cam with a duration of aboot 260, and lift of just aboot .5" works very well with not a bad idle, and its still very streetable. with the right tuning and knowledge, it will also pass emmisions testing
Old Jul 18, 2006 | 09:26 AM
n00blar's Avatar
Yeah, so far I'm inclined to purchase the kit from MSA; they're a bit expensive, but I'm still looking around to save a few bucks on this. I'm thinking of buying the non-turbo Stage 2, the kit which includes everything but the valves.
drey
Aug 10, 2011 03:54 AM
n00blar
Jun 19, 2007 07:14 PM
efrain
Sep 17, 2005 07:20 AM
280ZX_AV8R
Aug 27, 2005 06:08 PM
Dave
Apr 14, 2005 04:14 PM
