need ignition help!!!
Old May 15, 2006 | 05:14 PM
o.k. guys need some ignition help with my car, the little black box or ic module as some know it, is going for a dump, the cars running like crap, and detonationg lots, i dont know if the module will cause all of this, but heres my setup right now, i got an msd 6a box, blaster2 coil, and tach adapter. i want to know if there is a upgrade for that black box, or do i have to use the stupid thing. i found points to electronic kits for 90 bucks (crane), a far cry from the 220 that the box is, does anyone have info, or has used this setup before. please help guys, im dyin here.
Old May 15, 2006 | 05:23 PM
oh, and that kit is for the early points dizzy, are they basicly the same?
Old May 15, 2006 | 06:09 PM
We're talking about the modual on the side of the dizzy right? I think it either works or it doesn't. If it doesn't, the engine won't start. I don't think it is the cause of detonating.
If it's running like crap, it's most likely a fuel problem. Do you have an a/f gauge hooked up?
Old May 15, 2006 | 07:08 PM
Skully's Avatar
well module or no module you got one coming ...they said thursday..
Old May 15, 2006 | 08:42 PM
jfairladyz's Avatar
I told you about the Crane Cams kits. That replaces the module.
Old May 15, 2006 | 10:59 PM
the crane part # are bunk i tried, the fuel is fine, ive had this prob before, oh the work, but it dies more and more till it dont work no more
Old May 16, 2006 | 05:53 AM
naviathan's Avatar
Have you checked to see if the coil is overheating? Just because it's new doesn't mean it works. You might also want to check the clearances on the stator/reluctor in the dizzy. Proper air gap is .3-.5mm or .012-.020" by the FSM.
Old May 16, 2006 | 04:40 PM
the actual dizzy is good, its new plus i checked the air gap just in case, the coil overheating is a possibility, but i dont have a differnt coil to compare it to, and cause it dies at inconveniant times, like going up a 2 lane hill it really is hard to check, and it does start back up after a couple of tries, i just hope i can eventually get a new module, or the crane iggy thing. just gotta find one first
Old May 16, 2006 | 05:30 PM
jfairladyz's Avatar
Here ya go SHADY: XR3000 and: XR700
calebgz07
Jul 22, 2012 10:21 PM
dkrzan
Dec 11, 2011 08:52 PM
Whitesmoke
Apr 4, 2006 03:08 PM
280ZX_AV8R
Jun 5, 2005 01:28 AM
rifleman502
Dec 17, 2004 10:13 PM
