na parts rather then turbo?
Old Aug 16, 2006 | 03:37 PM
Steven280ZX's Avatar
i have a stock 280zx na engine rite now and im wondering if i were to get a turbo engine are any of the stock na parts better then the stock turbo parts and would it be better to switch those parts? i was told that the 82 na has forged crank an rods... does the turbo as well? if not should i switch em? things like that. enlighten me
Old Aug 16, 2006 | 05:13 PM
RodMoyes's Avatar
Doesn't post much...
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/zx-specifications-15404/
"Search" is your friend
"Sticky's" are even friendlier!
Rod.
Old Aug 16, 2006 | 05:33 PM
that link still doesnt tell me which pieces are better then the other... just what they are...
Old Aug 16, 2006 | 06:13 PM
Skully's Avatar
taken from the post...
Despite a common misconception, the F54 used in the turbo cars is NOT stronger than the F54 used in the non turbo cars. The ONLY difference was the Pistons. There were variations in the F54 castings, but they were the same for NA and Turbo blocks. The F54 is however considered supperior over the N42 blocks.
only difference other then the head..
F54 Non Turbo
Pistons: Flat Top
F54 Turbo
Pistons: Dished
Old Aug 16, 2006 | 06:15 PM
Skully's Avatar
Originally Posted by RodMoyes
https://www.zdriver.com/forums/showthread.php?t=15404
Rod.
knowing how to read...even better....
for everything else.... there is my boot up your ***...
haha
thxone's Avatar
Maybe this will help.
F54 Non Turbo
Pistons: Flat Top
Compression Ratio: 8.8:1
Horsepower: 145HP
Torque: 155LBFT
Factory Octane Requirements: 87 (US)
F54 Turbo
Pistons: Dished
Compression Ratio: 7.4:1
HorsePower: 180HP @ 5600 RPM
Torque: 203lb/ft @ 2800 RPM
They are basically the same except the pistons which are dished on the turbo for lower compression.
Old Aug 16, 2006 | 06:47 PM
****... i do need to learn to read thanks anyways tho
Old Aug 17, 2006 | 01:47 PM
turbobluestreak's Avatar
and the turbo pistons have different ring lands to help promote flex so they don't break the lands out under detonation. so don't get sneaky and try to find some old N42/N47 block pistons. They have the same dish as the later turbos just the wrong ring lands. But I know some people will say ring lands are unimportant once you get some much boost cranked up because you'll even break the turbo lands out.
tbs
Old Aug 18, 2006 | 02:25 AM
jfairladyz's Avatar
tbs
someone here actually tried to fit the earlier pistons into an F54 block and they weren't compatible. Sat up above (or was it below) the block deck.
Old Aug 20, 2006 | 01:35 AM
frank280zx's Avatar
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
why not use the flat tops ? that will give a more modern aproach. a friend o fmine ran a flat top 90a set up and loved it !! much less lag .. more drivable and good power .. also 8.5 orso is stock compression for most turbo cars now.
Old Aug 20, 2006 | 10:55 AM
lww's Avatar
lww
Head Muckraker
My pistons are flat tops... Oh, but they were custom forged...
Old Aug 20, 2006 | 12:19 PM
jfairladyz's Avatar
I plan to.
Jbaker1121
FS: 300ZX (84-89)
15
Mar 2, 2016 08:54 AM
83turbo280zx
42
Dec 18, 2012 08:38 AM
borini63
Aug 18, 2012 01:03 PM
Flacster
Dec 19, 2010 01:41 PM
BoostL28
Mar 25, 2007 10:15 AM
