my car is pissing me off!
Subscribe
Oct 14, 2006 | 11:42 AM
I hate my car right now!!! Just call her Christine. I start her up with no problem. turn her off and she won't start again. i redid the wiring going to the pump. She starts when she wants to not when i need her to. I have to go get it smogged because my reg is due today. ARGGHHHHHH what in the heck is happening here?
I checked the wiring behind the glove box and the fuseable links. I know I'm getting spark and air so what else can it be?
Reply
Oct 14, 2006 | 01:23 PM
check for fuel pressure. and make sure them injector's are fireing.
Reply
Oct 14, 2006 | 01:38 PM
need three things fire, oxygen and air. If they are all there then she should go UNLESS you changed the timing somehow. when you say won't start does it turn over but no pop or not turn over. two different problems you see. bad battery corroded battery cables/terminals (common cause most people too lazy to maintain battery) Do you smell gas out the tailpipe while cranking. my 83zxt would flood sometime and had to hold throttle wide open and give her a long crank to get started.
Reply
Oct 14, 2006 | 01:48 PM
Quote: need three things fire, oxygen and air.
Make that 4 things...
Fire
Fuel
Oxygen
Air
Note: if you're lucky enough to find some air with oxygen in it, you can skip the oxygen part
Rod.
Reply
Oct 14, 2006 | 03:21 PM
its wierd i get fuel some times and some times i dont. her injectors are firing fine have plenty of spark and air. its like she has an attitude when she wants to start she will when she does not she won't make sence?
Reply
Oct 14, 2006 | 03:53 PM
sorry tried to say oxygen, fuel and ignition source. type too fast.
Reply
Oct 14, 2006 | 04:21 PM
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAAHAHAHAHA!!!!!!! !!
Rogerz, you da man!!
Reply
Oct 14, 2006 | 04:23 PM
Skittle, you hearing the fuel pump when you turn the key??
Reply
Oct 14, 2006 | 04:25 PM
Rod, you crack me up!!
Reply
Oct 14, 2006 | 05:36 PM
some times it comes on some times its not. i know it has to be the wiring i just cant find out where.
Reply
Oct 14, 2006 | 08:58 PM
If it is an auto tranny....make sure it is all the way in park...mine wouldn't start till I pushed the shifter all the way...it was in park just not enough for the electrical connection to allow it to start. If it is a 5 speed then ignore me cause I am a dummy.
Reply
Oct 15, 2006 | 08:08 AM
then call your self a dummy.. jk yeah its a five speed thankfully. i'd have it no other way.
Reply
Oct 15, 2006 | 10:06 AM
hey skittle try the oil pressure gear in the car, all the relays and the sender unit, if any are not up to par, then it will not allow fuel, i had a car doing the same thing and thats what it turned out to be.
Reply
Oct 16, 2006 | 09:21 AM
is there anything that has to do with the afm? It started fine this morning then tried restarting it and nothing? what am i missing?
Reply
Oct 17, 2006 | 09:21 AM
U Know I Had A Problem With My 82 Turbo ... Up Until Now I Couldnt Get It Fixed.. I Had To Change Out Ecu's... Check Your Ecu With A Friends Ecu.. Same Year Same Make Same Model.. Etc.. Swap Ecus For About 5 Min See If That Makes A Differance.. Next Thing There Is A Little Vacum Advance Mod Right Next To The Air Flow Meter Box Un Plug That And See If Your Car Will Start...
Reply
Oct 19, 2006 | 01:50 PM
how are your wires?
Reply
Subscribe
