Installing Tokico HP Shocks & Spring
Old Jul 16, 2003 | 03:46 PM
icice9's Avatar
Super Siver & Black Stud
thats exactly what i did with my car... ive got the same set up and the same tire size that your planning on going with... and it fits perfect.. jsut as long as youve got the right offset for your rims.. you wont have a problem...
Old Aug 24, 2003 | 10:43 PM
TheeZ's Avatar
Coming to understand "Z"
wheels
well the easiest and most cost effective method of buying wheels is to get them in a package with tires, they come mounted and balanced plus hardware. Every thing for easily under $1000 and often times under $900. Check out Edge Racing, right now they've got a special package for $680! My cousin bought a nice set of black six spoke 16"x7" s with Faulken Ziex ZE-512 205mm for $860. Or The Tire Rack, they also have some nice sets. If you plan on using any of the wheels you find on those sites you will need wheel spacers to correct the offset and adjust your lug spacing. Those will hit you for $240 at Modern Motorsports. Those will correct 35-40mm offset found on fwd wheels and adjust your spacing to 4x100mm (civic or integra spacing). So if either of the wheel sites ask for a vehicle make just put in something like '91 integra. Best of luck and hope this helps!
PS-- for those reading Moder motorsports now offers "xtreme 13in big brake kit" Its availabe for '70-'83 but not yet listed! looks like 4 piston capliers and maybe a 5 lug pattern by the picture posted. Check it out!
Old Aug 25, 2003 | 10:38 PM
TheeZ's Avatar
most new rims and tires should be under 30lbs total. Figure on your rim weighing 15-20lbs and the tire around10lbs.
cbaumy34
Mar 11, 2014 03:25 PM
TeamRonin
Feb 10, 2014 07:11 AM
Flacster
Apr 3, 2011 10:54 AM
Keith_260z
Dec 29, 2007 12:38 PM
82_280zx
May 19, 2003 09:18 AM
