injector relay / resistor
Old Oct 13, 2008 | 01:04 PM
Zcarlover01's Avatar
Hi, I'm new to Z driver.com. I've read the rules before posting and I've tried to search for location of the injector resistor. I have no luck with it. I have a book thats showing it next to the brake master cylinder. But its not there in my car. Did they have resistors for the 80s?
My car is a 1981 silver 280zx if that helps?
Thanks in advance for all help. John
Old Oct 13, 2008 | 01:09 PM
njgheewala's Avatar
Dunkin' Donutz
We always love to see some picture of your baby, and welcome to the forum.
I can tell you these guys here are real expert at what they say so you are in a really great forum.
Welcome again!
Old Oct 13, 2008 | 01:14 PM
Welcome to ZDriver!
Is your Z by chance a turbo model? And are you looking for it because there's a problem w/ the car?
It indeed should look like this (technically from a 280z, but it looks the same for a 280zx):
Old Oct 13, 2008 | 01:32 PM
duowing's Avatar
NisTuner
As far as I'm aware like Nismo said, I think it only was on 81' 280ZX Turbos.
Old Oct 13, 2008 | 05:48 PM
the resistor for the injectiuon was on the cars till mid 81, then it disapeared. if you have a o2 sensor, you wont have the resistor. but it is located by the clutch master like the picture shows. so why you wanna know???
Old Oct 14, 2008 | 01:05 AM
The car is spitting at idle, a friend said it might be the resistor.
giving it too much fuel? And its non turbo.
Thanks for all help in advance.
Old Oct 14, 2008 | 06:28 AM
Spitting? As in black carbon out the tail pipe? Or rough idle? Misfire? Only when it's cold or all the time? Have you checked the timing? All sensor connections? Vacuum hoses? Fuel pressure? n e e d m o r e i n f o . . .
The resistor is rarely ever a problem, and when it is, the injectors likely won't spray at all. Answer the above questions so we can start to diagnose the prob.
wrenchwench
Apr 6, 2015 03:27 PM
83Zturbo
May 16, 2009 12:54 PM
duowing
Feb 20, 2008 04:07 PM
Creator
May 31, 2004 12:59 PM
ZWatcher
Apr 13, 2003 11:16 AM
