I do not have a turbo flywheel or clutch for my swap
Old Jul 11, 2006 | 03:54 AM
barrywood 24/7's Avatar
How much life can I expect out of a stock z clutch bolted to a turbo engine. If I gingerly use it with out a hammering it will it be OK. This is not the way I normally do things but this will be a exception. Now I know someone here has this set up the same way so hows it holding up for you?
Old Jul 11, 2006 | 09:55 AM
lww's Avatar
lww
Head Muckraker
Nearly as much as the turbo clutch. It should hold up fine if you're not thrashing on it.
Old Jul 11, 2006 | 01:21 PM
any non-turbo 2+2 Z (1975-83) is going to have the same 240mm flywheel you need. That is, if you have the money for a new 240mm clutch kit. About $100-130
Old Jul 11, 2006 | 03:27 PM
veyenyl's Avatar
It will hold up at stock boost levels. Once you turn the boost up to even just 9 lbs, it will slip on WOT runs.
Old Jul 12, 2006 | 07:04 AM
Excellent, I do plan to upgrade as soon as the setup acts up on me.
Old Jul 12, 2006 | 01:33 PM
duowing's Avatar
NisTuner
as far as the flywheel goes, can't you just use the flywheel that's already on the auto turbo?
Old Jul 13, 2006 | 09:41 PM
lww's Avatar
lww
Head Muckraker
Yes, just get a clutch to match. If I remember correctly, you may have to push out a dowel pin in the auto flywheel before the NA clutch will seat properly.
19-300zx-90
Feb 15, 2013 08:06 AM
VenomousZX
Jun 18, 2010 10:16 PM
sticky280zx
Mar 10, 2008 11:28 PM
allmotor300z
Feb 3, 2005 07:07 AM
tsefreeflow
May 15, 2004 11:30 PM
