How to replace ignition switch in 82?
Old Sep 23, 2002 | 06:29 PM
lifegrddude's Avatar
Externally Wastegated
Re: How to replace ignition switch in 82?
Are you replacing the ignition switch or the ignition assembly (the one that holds the key in). If you're just replacing the ignition switch, look behind it and you'll see two screws (after taking bottom steering wheel cover and the panel with the light on it off). If you take those two screws out, you'll be able to slide the old ignition switch out and replace it with a new one without having to drill it out and buying a completely new assembly. Much cheaper too. I did that because I couldn't pass tech at the race track. Good luck, let me know if you need more details.
82ZXT
BStuck
Nov 17, 2013 10:44 AM
pete8717
Aug 31, 2008 03:19 AM
3XAZOWNER
Jul 29, 2008 01:01 AM
Turbo86
May 25, 2007 08:50 AM
Dryz
Sep 30, 2002 12:54 PM
