HOT soak hard starting probs..
Old Jul 21, 2009 | 01:39 PM
bojo68's Avatar
Mine's been having hot soak starting problems every since I've had it, usually I can get around it, but it's a pain. I think there is a bad electrical connection in the car somewhere, because every once in a great while it will just flat shut off. Often I can get it running again before I even drift to a stop. Every now and then though it won't restart, for up to 10 minutes.
There's also EVERY time it's warm, and I stop somewhere for more than about 3 minutes, It doesn't want to start. When it does, I'll get steady continuous misses on from one to several cylinders. After free reving it for a little while, the cylinders start coming back in, one by one. The injectors look freshly installed, by a moron. They're different colors. I"ve only heard the injector cooling fan come on once, the car usually runs very cool, so I don't believe it's hot enough to trigger the fan.
I'm thinking I've got some kind worn out gummed up sticky injectors, new looking or otherwise, and a bad connection in an electrical circuit somewhere.(haven't cleaned up all the connectors yet) Anybody got any experience that would shed light on my current assumptions??
Edit: ign module has been replaced, no change. Wondering if maybe pick up coil in dist could be culprit.
Old Jul 21, 2009 | 01:42 PM
Have you checked the spark plug tips to see if they are all the same? What color? Any build up?
Old Jul 22, 2009 | 12:55 PM
bojo68's Avatar
Ah, no! When it is running,(most of the time) it runs so well I never figured it could be plugs, and have never had a plug out, or a wire off.... Valve cover hasn't been off either... I spose yer right, it would make sense to check something that simple, mostly cause it's so easy... I don't think it's likely, but on the same hand, this whole set of events isn't likely...
Old Jul 22, 2009 | 01:00 PM
I don't mean the spark plugs are bad (though they could be). You said you think an injector might be sticking... a spark plug tip will tell you how the cylinder is running.
Old Jul 22, 2009 | 01:36 PM
bojo68's Avatar
I've heard jim Lister say that old gummed up fuel injectors can stick hot only, but never seen it. That's what I was thinking. It would be worthwhile just to see if there's any correlation between fuel injector color and spark plug readings. It got 29.8 mpg driving back from Seattle 3+ yrs ago, and I didn't know it was a 5 speed, and drove it in 4th all the way...
Old Jul 22, 2009 | 03:06 PM
BlueKitsune's Avatar
Intrawebz Wizard
Try putting some Lucas fuel system cleaner in your Z, that helped my Z a lot.
Other then that idk
Domi's 75 280z
May 31, 2015 12:25 AM
jdina8890
Jul 2, 2014 09:09 AM
Mangrum1184
Dec 27, 2011 06:31 AM
centralflZ
Aug 18, 2009 09:01 PM
dum-bass
Jan 12, 2007 06:25 PM
