HELP! Urgent, pistons backwards.
Old Jul 6, 2012 | 02:49 PM
supertuner12010's Avatar
Ok well rebuilding an l28et for a buddy, project was slow as making sure everythign had been over.
Well after some bad news, car needs to be up and running asap. So given the stress of time, I finished honing the block and started installing rings and dropping the pistons in. Finished maybe 15 minutes ago and as I turned the engine up to put the front timing cover on I noticed that not only did I install the pistons in the opposite order, but I also installed each one backwards. So that the notch is facing the flywheel. Engine still spins freely...
Can this be detrimental to the engines opperation? And am I goign to have to pull all the pistons back out and reinstall?
Old Jul 6, 2012 | 10:55 PM
Just pop them out and drop them back in. It'll only set you back about an hour at this point. The order isn't such a big deal as long as you have new bearings and rings
KSpakes87
Dec 3, 2011 08:13 PM
bdp159
May 31, 2010 06:44 AM
chrischicoine18
May 12, 2006 10:18 AM
'76Z
14
Aug 4, 2004 08:58 PM
Z_WRECKER
Mar 24, 2004 03:17 PM
